Anybody using reds w' Eagles?
Old Jul 3, 2009 | 03:55 PM
B and B's Avatar
Loved
Community Favorite
Default Anybody using reds w' Eagles?
LS, Eagle rods. I ordered black according to my math and Earls chart. And rod big end measurements from a machine shop that I'm doubting.
Way too tight...I'm down to reds now and getting around .001
Somethings weird here. My damn bore gauge won't go that small so I had to get someone to measure the rods....but they said 1.8910 to 1.8912.
I'm gonna start over, re-check crank, and I guess rods. Don't have my notes right now but the crank journals were in the normal range. And my mains worked ok with the chart...just a little tight with blacks, ordered a brown to re-check with there. Almost ready to just order ACLs.
If I miss my tune date at T1=/self.
Old Jul 3, 2009 | 04:58 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Anybody using reds w' Eagles?
I've always ran greens on eagles and never had a problem
Old Jul 3, 2009 | 05:35 PM
smoovy's Avatar
I am not using Eagles but I currently use reds on my rods and there perfect for my application(PAUTERS).
you should post your measurements from your rod & main journals and any other info. we need to know to help you. I know buying bearings isn't cheap. a easy $180 for OEM bearings can easy make it to $250+ easily if measurements aren't correct. I posted mine when I needed help. there was something in my math that wasn't correct.
https://honda-tech.com/forums/tech-misc-15/engine-bearing-difficulty-2064206/
GoldLudeRay
Sep 13, 2008 03:51 AM
DCRB
Sep 1, 2008 08:42 AM
richeybrooks
Jun 12, 2006 04:09 PM
2BFI
Feb 11, 2006 08:43 PM
paulzy
Dec 22, 2001 10:41 AM
