anybody running 2stage of nitrous??????
show me you 2stage set up
i was thinking of putting 2 direct port set up one on top of the manifold(150shot)and one on the under side(100shot). and hitting the 2stage when i get in 2gear.
would this be good or bad? would the nozzel intefere wit one another?should i juste use a single nozzle or a plate systeme instead?
the reason i whatn to do this is beacause i cant spray 250shot of the line it does not hook(tried it on a friend car basicly same set up as mine)
i already have a v8 direct port kit and 2bottles so its no probleme goin 2stage.
you might want to look into a progressive nitrous controller to deliever the nitrous. then you can spray off the line at like 10% and ramp up to a full shot half way doun the track
summit and jegs should carry them
vectorsolid
Jun 18, 2008 11:17 PM
