Any problems with a long oil drain line
Old Jun 8, 2011 | 05:39 PM
5thgen's Avatar
Default Any problems with a long oil drain line
My setup has the turbo placed about where the intake box would be on a 92-95 civic. I'm wondering if anyone has any experience with a drain line that is going to be this long.
I would estimate it at about 4 ft. I am using a 10an line (.5" I.D.), but I could use one size up if there was going to be an issue. I already have some solid .5 i.d. stainless to make my line though.....and a bigger size would require buying the material for it.
Old Jun 8, 2011 | 06:32 PM
Casey's Avatar
Default Re: Any problems with a long oil drain line
as long as it doesnt angle up in any way and the drain on the pan is high gravity is going to do its job and be fine.
Old Jun 8, 2011 | 06:56 PM
MR.johnson's Avatar
what he said^
-10 and running down you will be fine.
Old Jun 9, 2011 | 05:03 AM
Turbo-LS's Avatar
x2
Id like o se a pic of this though
Old Jun 9, 2011 | 06:07 AM
5thgen's Avatar
Obviously the turbo isn't there, but this should give enough of an idea.
I wanted to put a/c back on the car and use a full length radiator. The setup may not be ideal, but it'll work for what I want.
Old Jun 9, 2011 | 08:11 AM
welfarepc's Avatar
it will work fine. just make sure it slopes down the whole way.
TylerB
Feb 20, 2008 10:50 PM
mrx
Oct 30, 2005 09:08 AM
94lsboost
Nov 28, 2004 03:33 PM
MikeMAN
Apr 19, 2004 07:30 PM
tgreaves
Dec 29, 2003 11:42 AM
