Any play is bad..right ?
Old Jan 17, 2003 | 03:33 AM
Pcart's Avatar
Default Any play is bad..right ?
I got a t25 the other day, and there is no side-to-side play at all,but the wheel does move back and forth, it spins free without scraping. I know there are tolerences but i dont want to put this in my car and have the bitch not work.What is to much play? Who does rebuilds ? Thanks
and if you got a good t25 cheaper than i can get this one rebuilt for let me know.
Old Jan 17, 2003 | 05:17 AM
rjardy's Avatar
Default Re: Any play is bad..right ? (Pcart)
remeber it is a floating bearing meaning that it relies on oil as a cushion in the bearings. if it doesnt hit anything, i would bench prime it and see if it goes away. If it firms up, i think that you will be okay to run it in your car.
Rob
Old Jan 17, 2003 | 06:20 AM
RAWB's Avatar
The shaft is going to move a little. The only way to really measure it is on a machine that can put it under load and take measurements- obviously something the normal person doesn't have readily available. Typically, as long as you can't move it enough to touch the housing, you're olay. Is the housing scorred at all? If not, then you should be okay- that would mean the previous owner had no problems with it. Unfortunately unless you take it to a turbo shop, the only way to REALLY find out is by putting it in the car. GL
Old Jan 17, 2003 | 06:35 AM
Tony Starks's Avatar
Default Re: Any play is bad..right ? (RAWB)
I would get it rebuilt. I put in a used turbo with the same type of play that you are talking about and the bearings burned the first time I boosted. The turbo was getting oil and everything was installed correctly, you just never know with a used turbo. Did you know the owner, or was this an Ebay transaction?
Old Jan 17, 2003 | 06:54 AM
lazerus's Avatar
Default Re: Any play is bad..right ? (Tony Starks)
You can always prime it (with oil), and use your air compressor tool to force air through the turbine inlet.
it should give you a pretty good idea if it's trashed or not.
ej1252
Nov 24, 2007 04:52 PM
Revi
Oct 27, 2006 02:06 AM
AssPenny
Feb 8, 2006 09:42 AM
fire7882
Sep 18, 2002 10:06 PM
blowncivichb
Jan 5, 2002 07:58 AM
