any idea if this is repairable
Old Apr 28, 2005 | 11:15 AM
IntegraTypeR's Avatar
Default any idea if this is repairable
i bought this tranny from a good guy on this forum and the shipping company broke one of the tranny bolt threads...here are the pics:
i wanted to ask is it possible to ask FedEx to pay for the repair (i dont want to to return and get full refund)...only want repair....and do u guys have any idea how much will this cost to repair ?
thanks,
Kamal
Old Apr 28, 2005 | 11:22 AM
dustin's Avatar
Default Re: any idea if this is repairable (IntegraTypeR)
It'd probably be cheaper to just get a new outer housing and swap the internals over... Find someone with a junk tranny that still has a good housing.
Old Apr 28, 2005 | 11:23 AM
s2kdre's Avatar
i only have two bolts on my tranny mount anyways. Just try to get a new or used case but you should be ok with just 2 bolts because you have a bottom tranny mount to support it also
Old Apr 28, 2005 | 11:24 AM
s2kdre's Avatar
Default Re: any idea if this is repairable (jdmhonda)
and the outer case you dont have to swap anything over you just have to reseal it.
Old Apr 28, 2005 | 11:26 AM
Muckman's Avatar
Moderator in Chief
Its fine. Just bolt it up, it wont go anywhere.
Old Apr 28, 2005 | 11:29 AM
dustin's Avatar
The lower torque mounts aren't load/weight bearing... It will probably be OK but personally I would probably try to fix it somehow.
Old Apr 28, 2005 | 11:30 AM
mattssi's Avatar
If you do install it like it is, there is a missing 14mm bolt there. fyi.
Old Apr 28, 2005 | 11:38 AM
Adriano's Avatar
Default Re: (mattssi)
If you have the piece that broke, just get it welded back in. Is not the big of problem to fix
Adriano
Old Apr 28, 2005 | 11:53 AM
Default Re: any idea if this is repairable (dustin)
how much are these casings usually? are they expensive or cheap? and guys do u think while am at it to fit an LSD? am not usre sure where an LSD fit...is it inside that case or it can be added externally....i know how an LSD looks like and that broken bolt thread looks where the LSD fits right?
Old Apr 28, 2005 | 11:57 AM
Default Re: (brryder)
i contacted gear speed and they said to call them ...they seem to have a quick solution for me, but wanna get ready for $$$...lol
Old Apr 28, 2005 | 12:00 PM
salt's Avatar
Just have a welding shop fill that in and then retap it. Should be less than $100.
Old Apr 28, 2005 | 12:18 PM
PM-Performance's Avatar
yes, a machine shop can weld that right up and drillit out and retap it.
My last motor in the ITR had that done and it held great
GSR_hatch936
Feb 2, 2008 04:34 PM
cr-x si
16
Jun 19, 2003 09:13 PM
JV
Jun 1, 2003 05:31 PM
spladam02
Dec 8, 2002 06:42 PM
Turbohatch
Oct 26, 2001 12:25 PM
