Any downfall to gapping a spark plug too tight?
Old Jul 14, 2006 | 08:18 PM
dunkd's Avatar
Default Any downfall to gapping a spark plug too tight?
I know some guys are gapping all the way down to 16-18 now. Is there any downfall to going TOO tight on a gap? Ive seen a lot of times people say start high and work your way down to what works.
Old Jul 14, 2006 | 08:22 PM
B18C1CYA's Avatar
Default Re: Any downfall to gapping a spark plug too tight? (dunkd)
well my plugs are at .014 and made 685 whp on 32.5 psi
93turbo16's Avatar
Usually the most gap you can run without blowing out the spark the better. The only real thing I have seen sometimes, is a tight gap can give a little rough idle. Richening the mixture usually helps a little.
Old Jul 14, 2006 | 08:40 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default Re: Any downfall to gapping a spark plug too tight? (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Usually the most gap you can run without blowing out the spark the better. The only real thing I have seen sometimes, is a tight gap can give a little rough idle. Richening the mixture usually helps a little.</TD></TR></TABLE> thats what i was always told.. thats why you run msd or any ignition box to open the gap more without getting spark blow out
Old Jul 14, 2006 | 08:47 PM
dunkd's Avatar
Default Re: Any downfall to gapping a spark plug too tight? (1QwIkEf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1QwIkEf &raquo;</TD></TR><TR><TD CLASS="quote"> thats what i was always told.. thats why you run msd or any ignition box to open the gap more without getting spark blow out </TD></TR></TABLE>
ok but why not just run oem ignition w/ a tighter gap to get rid of spark blow out?
Old Jul 14, 2006 | 09:04 PM
iBrandon's Avatar
running .013 gap...idles 14.7
Old Jul 14, 2006 | 11:05 PM
T4eg's Avatar
Default Re: Any downfall to gapping a spark plug too tight? (iBrandon)
.017 gap here 730+whp on dynojet stock ignition
Old Jul 15, 2006 | 09:21 AM
dunkd's Avatar
You guys with the tight gap have no other issues that arise after taking the gap so low? Street driveability or decrease in life of plug?
wtsapexipowerfc
Sep 18, 2010 01:37 AM
eg:R
Mar 3, 2009 12:45 PM
planoguy36
Jun 7, 2006 07:29 AM
98typer794
Sep 20, 2003 10:57 PM
advan7
Apr 13, 2002 02:31 AM
