Any a/c experts on this board?
Old Jul 4, 2004 | 12:20 PM
boostismycrack's Avatar
E-thug
Default Any a/c experts on this board?
My high side reads 350 psi at idle and over 400 at 2-300 rpms, then the compressor shuts off, sometimes it blows the check valve. I have changed the compressor, condensor, expansion valve, dryer, evaporator and the high side line from the compressor to the condensor. I know it still seems like there is a restriction somewhere, but I can't figure it out. It is there any way to test each component individually? I am tired of just buying and swapping parts. I also had the system flushed, held on a vaccum and charged with 1.5lbs of 134a. I also checked my fan, it is comming on and blowing in the right direction.
Old Jul 4, 2004 | 03:44 PM
E-thug
Default Re: Any a/c experts on this board? (boostismycrack)
anyone with any a/c experience want to comment?
Old Jul 4, 2004 | 06:36 PM
IntegraTypeR's Avatar
https://honda-tech.com/zerothread?id=899399
Old Jul 4, 2004 | 07:51 PM
E-thug
Default Re: Any a/c experts on this board? (IntegraTypeR)
thanks for that thread, but I still don't know what to do next, i don't think its an airflow issue, but a blockage on the system, just can't figure out where.
Old Jul 5, 2004 | 05:41 AM
b_ron007's Avatar
the compressor cuts out because of a high pressure switch. are you sure ur condensor fan is coming on? what car? does it cool while driving on the highway?
Old Jul 5, 2004 | 05:42 AM
b_ron007's Avatar
does it even cool at all?
Old Jul 5, 2004 | 09:00 AM
scttydb411's Avatar
has any part of the system been opened (cracked hose, leaks, etc)? if so the dryer has probably become soaked with moisture and needs to be replaced. it's an aluminum cylinder about the size of a soda can usually mounted near the washer resivior and power steering pump. you'll see metal lines running to it.
anytime your a/c system is opened due to service or leaks it should be replaced...you can get them at pepboys for $25. it has a pack in it that pulls moisture out of the system and prevents it from screwing up your system. it'll pull humidity out of the air if a line is disconnected. evacuating the system for a long period of time sometimes helps, but since they are so cheap just put one on and then vac down the system and then recharge.
johnymoeax
Oct 22, 2009 07:56 PM
oldskoolaccord
Jul 10, 2009 02:37 PM
FamilyGuy
Nov 23, 2008 05:28 PM
SpoonFedHatch
15
Jun 12, 2004 08:04 PM
LsTurbo91
Aug 5, 2002 07:05 PM
