Anti-Lag base settings
Old Jul 9, 2008 | 09:30 AM
cpl rampage's Avatar
Default Anti-Lag base settings
Hey, I ahd a few questions about setting up anti-lag on crome gold, I am testing out a few features of gold, but Kind of apprehensive about this one.
Here is my setup:
Eagle/vitara D16Z6
DSM injectors
cast mani
garrett T3/T4 57 trim .63 a/r
2.5 inch dp to 3inch exhaust
Currently tuned by me on crome pro @ 15 psi.
I know anti lag isn't really necessary, but i would at least like to check it out, some time later this year i will hit up the track and want to see how als affects my times. The one this is I dont know what settings to start with as far as how many degrees to retard, and how much fuel to add. I hear people say 30 to 40 degrees retard, but i was wondering if anyone with als could give me some hints. on where to start.
Thanks
Old Jul 9, 2008 | 12:42 PM
quicksilver1689's Avatar
i ♥ snails
expieriment is what id say just dont get too anti lag happy, things tend to heat up pretty fast. Most people seem to run anwhere from 5 degrees btdc to injecting on the downstroke. Id say just see what values alow you to build boost and not get too aggressive with it.
Old Jul 10, 2008 | 04:15 AM
Default Re: (quicksilver1689)
Well i got to mess with it a little bit last night, the whole thing is i was expecting it to work around 4000 or so but it really didn't do much till i brought it up to 5000k. I tried retarding 10 to 40 degrees, and fuel enrichment i went to 1500 (i think this is way too hight from what i read in pgmfi, but ill test it out.) i believe. Is there any maximum to how much fuel I can input with the 450's, i don't know how 1500 ms is related to duty cycle etc. but either way I got it to work, and made around 7 psi at a stand still. Not bad, now the only thing i need to figure out is why vtec doesn't work in crome gold?
Modified by cpl rampage at 8:13 AM 7/10/2008
Old Jul 10, 2008 | 09:24 AM
boosted k20's Avatar
Default Re: (cpl rampage)
i usually set my fuel anywhere from 20 to 150... depends on the injectors. as for timing i usually pull 30-35* to build boost off the line. the higher the rpm the better the boost will build. most setups i put to around 6-7K ( launching on slicks)
Old Jul 10, 2008 | 10:08 AM
Default Re: (boosted k20)
yeah, i went and messed with it a bit on lunch break, but one thing i forgot to do that i read on pgmfi was to set the launch limit resume to something lower then 50, as far as how high to set it, yeah i had it at 5, i havent been really launching with it yet just because i have bald street tires on it right now, but when i get a better feel for it i will prolly up the limit. its just scarry reving that high since it is only a lil d series, not that i dont have faith in my engine building skills lol, but the top end is stock for now.
Old Jul 11, 2008 | 03:39 AM
i have my launch limit resume and rev limit resume at 5rpm. some setups i have it at 0
TurboB16A300Hpteg
Apr 14, 2008 02:16 PM
Agtronic
May 27, 2007 06:26 AM
EH2LS
Sep 6, 2003 11:04 PM
Dream
Sep 1, 2003 01:35 AM
B18C-RnVA
May 10, 2002 06:29 AM
