another mild build...
Old Mar 7, 2009 | 08:51 AM
teddy_dc2's Avatar
Default another mild build...
it's been nearly two years since i've done anything to my car. last i did was a suspension upgrade and never really touched it since. i really wanted 500+ hp but i figured that the teg chasis wasn't the way to go for me and besides most of my parts are around the 400hp mark. i just wanted to finish it off with a slight build. aiming for 400-425whp with no sleeves. (this is a weekend car not dd) i'm kinda iffy about the sleeves because the motor has almost 160k but still shoots a 220psi across. i really don't want to sleeve because that'd only make me want to change the setup. thinking cp 9:1, eagle h beams, acl bearing. do i need the arp main bolts? as far as putting the rods and pistons in, is this something an amatuer can do?
here is the list:
stock b18c1 @ 7psi
turbonetics t3/t4 .57 trim
ram manifold
tial 38mm
edelbrock victor x
3" down pipe and cat back w/no cat
arp head studs
clutchmaster stage 3 w/8lb flywheel > ugrading???
rc 550cc injectors > upgrading
walbro 255lph
p28 crome pro basemap> upgrading
Old Mar 8, 2009 | 12:52 AM
SD_Lurker's Avatar
HT White Ops
Default Re: another mild build...
No on the main studs unless you plan to have it line honed. Also, I suggest you get a fresh hone on the block or just go 81.5mm. With that many miles it would be a wise idea to have the block honed. Of course I shouldn't have to tell you that cause I'm sure you already knew that. If not I suggest you have someone else do the labor for you.
Old Mar 8, 2009 | 05:32 PM
teddy_dc2's Avatar
also my buddy was telling me to go with oem rod bearings instead of acl bearings because of the clearance between them doesn't really allow a lot of oil flow. would it be wise to go oem? any suggestions on what type of piston? i was thinking cp 9:1 because that's what i've seen most people suggest..
Old Mar 8, 2009 | 05:54 PM
sp00led's Avatar
Laskey Racing built my motor with ACL bearings. Still runs great. I hear a lot of other builders using OEM though. Just my .02
Old Mar 8, 2009 | 06:01 PM
pauld's Avatar
built my LS using ACL bearings, ran nitrous through it, then turboed it and ran it at 15 psi, generally stomped on the car daily....no problems. Same with a JRSC d16z6 build for a friend, and some others. DO check your clearances, though. I suppose that the OE honda ones have great sizing choices for the **** builder, but the ACL goods have treated me well on a few builds.
Old Mar 8, 2009 | 06:40 PM
teddy_dc2's Avatar
yeah i had wanted to go with sleeves through laskey racing but maybe another setup in a lighter chasis. the main question i had was is it pretty easy installing the rods and pistons or leave it to a pro. i'm pretty knowledgeable about cars and if given the right instruction i believe i can do it. it's guessing it's similar to removing the head on a gsr.... and is 400whp pretty much where you want to be at with stock sleeves?
nebulight
Mar 1, 2007 09:37 PM
ebp_dc2
Sep 25, 2005 01:50 PM
VTECisSeXY
Dec 7, 2004 07:17 AM
s2kkid
Oct 31, 2004 06:19 PM
dunkd
May 21, 2004 04:41 AM
