Another Clutch question
Old Apr 15, 2005 | 02:40 AM
Green Lude 93's Avatar
Default Another Clutch question
i know. another clutch question. but all the searched results i found related to 250 to 300hp. which clutch do you guys think would be sufficent to support about 500-550hp? I prefer having a spring hub. I looked into twin plates but i dont want to shell out 1200 for a clutch. But if that is what im going to have to get then i guess that is what i will get but i want to know my other options. Im doing a major overhall right now on my motor and this hp is what i am gearing my goal towards. So hp is technically unknown.
Old Apr 15, 2005 | 03:38 AM
m R g S r's Avatar
Default Re: Another Clutch question (Green Lude 93)
i just told jeff evans i wanted to make 550-600whp and he said i need a twin disk clutch......exedy.....i have the 2md and he said it would probally only hold for one or two dyno runs . . .
Old Apr 15, 2005 | 03:46 AM
SlowReaction's Avatar
Default Re: Another Clutch question (m R g S r)
Though 1200 for clutch is a lot I think its well worth it. Something you wont have to worry bout later on in the future. Twin disk usually last pretty long and when they wear out I think the replacement disk are pretty cheap. I went with a Exedy Twin myself and wouldnt trade it for anything elses, except maybe a carbon twin.
Old Apr 18, 2005 | 01:07 AM
Default Re: Another Clutch question (SlowReaction)
thanx guys. it seems as if i need to just break down and get the twin disk.
Old Apr 18, 2005 | 03:44 AM
Cor ey's Avatar
I can has title
Damn, civics got the shaft by ACT. Don't they only make like a 490 ft lbs clutch for Honda/Acura? I know for the Evo's they have the 6pad discs that hold upto around 700.
If you do go with the twin plate, I know that it is probably going to chatter and make a good bit of noise.
Old Apr 18, 2005 | 03:49 AM
Default Re: Another Clutch question (96B_97E)
it probably will chatter but i know that it is going to be smoother than a springless hub. i wont mind the twin plate. i just dont really want to fork out another 1200 after spending a grip on the motor. oh well tho.
Old Apr 18, 2005 | 08:41 AM
95GSRTT
Guest
Posts: n/a
While I have had bad luck with the RPS clutch and when I pull my tranny this weekend Im HOPING its the flywheel, RPS does make clutchs that hold like 500 lb/tq which will easily hold 500-550 whp.
And they are roughly like 400 through Marty T on HT.
Modified by 95GSRTT at 6:12 PM 4/18/2005
steveharrmr23
Jun 22, 2009 12:42 PM
dunkd
Apr 2, 2006 07:53 PM
rwcdrums
Mar 27, 2005 06:30 PM
Dee A Nine
Sep 18, 2004 12:27 AM
