another build need opinions
Old Feb 14, 2009 | 06:30 AM
g0tgot's Avatar
Default another build need opinions
ok i got a DRAG 50TRIM ball bearing turbo with a log mani
38 mm tial wastegate
gsr head fully machined, itr valve train gsr cams
ls stock block, fully balanced bottom end
gsr tranni
my questions lie on what piston to use, LS or GSR
AND would i see a huge benefit on cashing out on some ITR cams
i have a hp goal of 350-400hp daily driven....
everything is allready out of the machine shop, i have gsr pistons and ls
LS i thought was ideal due to the low compression....just need some opinions...thanks!
Old Feb 14, 2009 | 06:49 AM
vadimkag's Avatar
Default Re: another build need opinions
With LS pistons should be 9.9:1 compresion recio, so with a good tune your good to go. I think with GSR pistons should be around 10.4:1
But If you put thicker head gasket like .039 (stock is .029) should give you 9.7:1 on your LS Vtec with LS (P04) pistons.
Old Feb 14, 2009 | 07:38 AM
g0tgot's Avatar
what is the reliability on a thicker head gasket? is it OEM honda?
Old Feb 14, 2009 | 08:31 AM
vadimkag's Avatar
You want reliability - go with Cometic gaskets, they have any bore size and thickness.
Everyone use's them for turbo I got mine oversized from them too.
Old Feb 14, 2009 | 10:09 AM
TheShodan's Avatar
Moderator
OH boy, this is going to get ugly... fast.
Old Feb 14, 2009 | 10:15 AM
silv3rCOUPE's Avatar
i thought that the ls pistons did not have the relif for and ls vtec build i thought you neede to use b16 or gsr pistons or any vtec piston
Old Feb 14, 2009 | 10:20 AM
vadimkag's Avatar
you can use any of those GsR, ls, b16 or ctr and itr they all will work fine for ls Vtec, it just differense in compresion ratio.
Old Feb 14, 2009 | 10:26 AM
boostedeg302's Avatar
i would go with the ls pistons due to the slightly lower compression ratio and i would get an oem honda headgasket. The itr cams will definently make more power than the gsr cams and will help you reach your goals a lot easier
Old Feb 14, 2009 | 10:45 AM
vadimkag's Avatar
That would be perfect choise...
1sick4dr.
Sep 25, 2006 10:06 AM
saleensolution
Mar 23, 2005 11:17 AM
lscoupe
Feb 18, 2005 04:24 AM
CANTFAZZDISCHIT
May 17, 2004 09:24 PM
