allstar performance breather tank install
Old Jun 27, 2011 | 04:37 PM
egcoupe007's Avatar
Default allstar performance breather tank install
which is the proper way to install the allstar performance breather tank (all36109) with 2 bungs on it,a filter on top,and a drain valve at the bottom, to my ls vtec turbo i removed the black box behind the block and plugged it i have the 2 hoses routing from the back of block to each side of the catch can at high rpm on the road i notice the can fills up with oil quick and it shoots out thru the filter within the same day i have to drain it i kno is high pressure blow by any suggestion on how to prevent this from keep happening
Old Jun 27, 2011 | 04:49 PM
egcoupe007's Avatar
Default Re: allstar performance breather tank install
does anybody have a answer for me
Old Jun 27, 2011 | 04:52 PM
egcoupe007's Avatar
proper installation for my ls vtec turbo
Old Jun 27, 2011 | 04:53 PM
egcoupe007's Avatar
wats anybody
Old Jun 28, 2011 | 04:59 AM
BigMike0147's Avatar
I'm not sure what to tell you with this. It sounds like you're on the right track, Make sure the your bungs/can are higher than the level of your ports in the back of the block. This might help some.
Hopefully I don't have the same issue as I have the same breather setup, but I won't know until I get my motor/clutch broken in and turbo/tune installed.
egcoupe007
Jun 30, 2011 08:07 AM
egcoupe007
Jun 29, 2011 03:33 AM
egcoupe007
Jun 28, 2011 10:01 AM
postman
Jul 27, 2007 03:00 PM
riceball777
Jan 4, 2006 12:24 PM
