all in one gauge solution, where to buy?
Re: all in one gauge solution, where to buy?
ok
but it only reads the stock sensors
what hardware will i need for it to monitor oil pressure water temp oil temp etc.
I like my tunerview II there pretty badass and the price isnt that bad if you look at the price of each individual gauge that it replaces
not to sound like a jerk, but i doubt the tuner is going to be driving with him day in and day out. suppose an injector is leaking, or fouling out. for whatever reason his afr's are gonna change and a wideband will show him. Then he can figure out the problem instead of driving around with it and kaboom.
ok sweet
so this unit is pretty much plug and play?
with this unit plug and play, i will have an AFR reading, Water temp ? those are stock sensors right ?
You need a wideband to display wideband data. End of story. NepTune, eCtune, and Hondata allow up to 4 external sensors to be calibrated, and the TunerView supports this. You'll need those sensors to display anything that's not stock.
You could use it with them with out a problem but it wouldn't log/display timing and such. It would work like a standalone.
I know they've made them adaptable to Accel DFI and BS3 which allows you to view them live and record if you want to.
They are definitely not cheap. With the display and the sensors you wanted to monitor probably 2k maybe? I know they just came out with a Sportsman package but I honestly dont recall the price off the top of my head.
I took a quick screen shot of one of their demo logs:
You can view all this data through one of their dashes too... I found this image on hondatech.. good example-
But really if you have an FC that is your best bet
(hence your username )
does tunerview2 have the capability of monitoring oil pressure?
i have ectune ecu what hardware would I need to purchase to interface oil pressure into tunerview2?
to hook up the oil pressure is that a lot of work?
how much labour am i looking to pay?
i ordered the tunerview so i wouldn't have to buy gauges. i don't think it's a lot of work to hook up the oil pressure switch. i know i bought an oil pressure sender and plan on buying an oil temperature sender some time in the future. i ordered the auto meter 2246 oil pressure sender and wiring harness, it's what i've seen most people use with the tuner view
Could you please link me the website you got the oil pressure sender and the wiring harness.??
could this sender work as well?
http://www.auberins.com/index.php?ma...roducts_id=125
