Air Intake Temp Gauge?
Old Jun 30, 2003 | 09:29 PM
96IntegraRS's Avatar
Default Air Intake Temp Gauge?
I really don't have the $400 something to spend on the Autometer twin pyrometer setup, so I have a Venom LED readout connected to the stock IAT sensor on my manifold.
The gauge is intended to be used as an Engine Temp gauge, and Venom specifies that it can be connected directly to the stock coolant sensor - I checked and the voltages for the IAT and the coolant temp sensor are the same, so it works fine. Trouble is, it has no true markings for degrees, only about 10 LED's that simply display voltage as a sequential pattern on the readout.
So - I was thinking of buying an Autometer Temperature gauge, the question is, do the Autometer senders operate on the same voltages as stock?
Old Jun 30, 2003 | 09:51 PM
tony1's Avatar
Default Re: Air Intake Temp Gauge? (96IntegraRS)
I doubt they have the same scaling as an oem sensor. You'll probaby have to mount the autometer temp sensor.
Old Jul 2, 2003 | 11:34 AM
If someone is so inclined.... measuring the sensor (autometer) with a volt meter will indicate what the signal is, preferably cold and at operating temp, thus answering the question. Help?
Thepowderblue
Acura TL, RL & ZDX
Sep 10, 2012 08:52 PM
2k_Si
Jan 1, 2009 09:44 AM
erniecars
Jun 14, 2002 11:48 PM
