... air in the coolant system
Old Oct 28, 2002 | 11:38 AM
1.8T_EG's Avatar
Default ... air in the coolant system
... can air in the coolant system cause coolant problems like burning coolant?... also how do you chech for air in the coolant system?... and how do you bleed the system of air?... i read it somewhere here, but i cant seem to find the thread now... if anyone knows, lemme know... thanks...
Old Oct 28, 2002 | 12:02 PM
Etylorcen's Avatar
Default Re: ... air in the coolant system (1.8T_EG)
To get air out of hte system people have told me to open the rad cap and turn the car on for a while and the air bubbles should come out.
Old Oct 28, 2002 | 12:50 PM
shadowdawn's Avatar
Default Re: ... air in the coolant system (Etylorcen)
Exactly what the man said, let it idle for a good 15 mins to get anything out...
Old Oct 28, 2002 | 02:10 PM
Doodoo's Avatar
Default Re: ... air in the coolant system (shadowdawn)
Let it idle and wait for the fan to come on. When this happens the thermostat opens allowing coolant to flow. Keep filling until no bubbles. The best way is at a shop that has the fitting that hooks into the radiator cap. It creates a vacuum in the cooling system, then you suck up coolant. No bubbles. Cool Tool!!
Old Oct 28, 2002 | 04:09 PM
bmm89's Avatar
Default Re: ... air in the coolant system (Doodoo)
depending on the engine, there is also a bleed valve on the top of the block which you have to open, just filling the radiator will not remove the air on top... which could lead to overheating, etc...
Old Oct 28, 2002 | 04:17 PM
inspyral's Avatar
Default Re: ... air in the coolant system (bmm89)
run the car with the rad cap off with the heater blasting full-hot.
mlee19841
Honda Civic (2001 - 2005)
May 1, 2015 03:26 PM
motegicivic
13
Jul 4, 2011 05:35 PM
street_ride14
Apr 22, 2007 06:43 PM
speedy108
Jan 10, 2006 03:11 PM
fe519
Apr 30, 2003 01:30 PM
