At it again another project under my belt -part 1 turbo set up
HELLO,GOOD MORNIN'
After going through so many set ups I've done another one. Im just showing my manifold and turbo set up that was just finished today By Randy http://www.eville140.com
looking for 450ish on pump t3/t67 or whatever i can get. if more than im ever happier...lol
b18c benson sleeves
hondata s300
still confused on fuel set up
Enjoy
Modified by HybridcivicLS-T at 6:32 PM 4/12/2008
Modified by HybridcivicLS-T at 6:36 PM 4/12/2008
b18c benson sleeves
hondata s300
Enjoy
Re: (00hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00hatch »</TD></TR><TR><TD CLASS="quote">one bad *** DP</TD></TR></TABLE>
x2
x2
HELLO,GOOD MORNIN'
Re: (95jeremie)
u wouldn't even guess how much i paid! No one on this site can even touch it. no one that i know unless i made it and i don't know how. All high quality parts, he has almost every jig he made it exactly of what i wanted for less than a SS inlinepro manifold Manifold and DP flanges dump tube flex, everything for less than a brand new inline pro...lol
he makes them for fun and doesn't charge tons of labor.
keep an eye on that O2 bung downstream of the flex pipe... it looks like it might be directly undeneath the axle/midshaft.... meaning, the O2 sensor might get in contact with a rotating component..... other than that, great job!
Re: (thermal)
Would it be better if it pointed at a 45 degree angle either direction? I'm the one that put the above stuff together, just don't have a trans here. I was going off the o2 placement from a downpipe that came in a greedy(I know I spelled it wrong ) kit.
I will stop by the salvage yard on the way home tomorrow and check out the ls's they have.
Thanks
Randy
Thanks
Randy
Well, it may work just fine.... but remember that a 3 inch DP is taller... yup, I've done a 45 degree placement before and worked.... You should just mount the midshaft even without the tranny just to get a better reference.... just a thought....
HELLO,GOOD MORNIN'
Re: (Evile140)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evile140 »</TD></TR><TR><TD CLASS="quote">Would it be better if it pointed at a 45 degree angle either direction? I'm the one that put the above stuff together, just don't have a trans here. I was going off the o2 placement from a downpipe that came in a greedy(I know I spelled it wrong ) kit.
Thanks
Randy
i was goinig to send you a link...lol You can do whatever you think would be right. If you want to change it to a 45 degree angle then that's fine as well.
Thanks
Randy
ahobbs
Appearance Build Threads
06-30-2008 06:35 PM
Turbo-charged
Welding / Fabrication
80
03-15-2008 10:51 AM
