After Boost car running in limp mode
Old Aug 24, 2012 | 06:22 PM
SuperBowser707's Avatar
Default After Boost car running in limp mode
I have a boosted 01 accord f23(i4) 5 speed. Recently i have been throwing a code for vtec issues p1259. Since im boosted i think that the oil feed line is causing me to lose oil pressure at the sensor. From what ive read vtec works off of the oil pressure sensor to engage. So im wondering if there is a way to bypass the sensor. My oil level is upto par so i know the code isnt being thrown due to low oil. Havent pulled the solenoid yet to see if its clogged(will do tomorrow). Also Im not running an oil pressure gauge so i have no idea what the oil pressure is at the sensor. Any help or advise would be greatly appreciated
ps my oil feed line is not restricted because its a journal bearing turbo so that maybe the cause of not enough pressure to allow vtec to engage
Old Aug 24, 2012 | 06:42 PM
EsotericImage's Avatar
Retired Moderator
Default Re: After Boost car running in limp mode
I hope your not running the same oil pressure source for both vtec and feed line..
Oil pressure gauge is pretty cheap, id recommend using one.
http://prosportgauges.com/Clear-Lens...ge-52mm-1.aspx
Old Aug 24, 2012 | 08:38 PM
its off the back of the engine block where the oil pressure sensor is and i was thinking about picking one up since they are cheap
figure 9 on the link shows where it is even though this is for a d series
http://turboneticsinc.com/forum/turb...civinstall.pdf
Old Aug 24, 2012 | 09:43 PM
wantboost's Avatar
Who is Mr Robot?
horrible way to do it... the pressure sender has been know to snap off when run like that...
you need to remote mount it or buy a sandwich plate and run the oil feed from there.
you cannot bypass the sensor... that's the failsafe if you have some sort of oil pressure issue it disengages vtec to prevent damage. If the ecu doesnt see that sensor it won't engage vtev since it doesn't know if the minimum pressure requirement has been met to engage the vtec solenoid.
The turbo feed line should not be causing vtec issues, unless you have some stupidly large diameter feed line that's longer than it needs to be. Take the vtec sensor off and make sure the screen is clean, if its clogged that can cause engagement issues, or your sensor could be going bad
Old Aug 26, 2012 | 07:37 PM
xile6's Avatar
i dont think its oil since it should pop up with vtec oil pressure low, unless you disable the switch.
Check the soleniod and see if that works. then check the wires
Old Aug 27, 2012 | 04:24 AM
did the solenoid test it all checked out so im pulling the whole solenoid off to see if its clogged
Old Aug 27, 2012 | 09:39 PM
CO_RaceFab's Avatar
are you getting any other codes? oil pressure is not the only thing required for the vtec solenoid to activate. speedo, knock sensor, ect. you can bypass the oil pressure switch but i wouldnt suggest it if your on the stock ecu.
Old Sep 3, 2012 | 08:31 AM
okkay sorry for the no updates but i pulled the solenoid. filter was pretty clogged(due to little metal shavings from when i cut the hole in the oil pan, didnt clean it out to well i gues). so i cleaned put everything back on. Cleared the code and for two weeks havent had the issue
street_ride14
Feb 9, 2010 07:35 AM
ballisticej1
May 28, 2009 10:36 PM
MidwestAutoWorks
May 21, 2007 11:44 AM
DOHCarp
Apr 29, 2005 04:19 PM
