AFR issues Turbo B
Well, had my car tuned but found issues on Dyno. Found that the distributor was losing tach input at high RPM and was breaking up also the throttle body gasket had a leak. But the car idled and would run. Brought the car home and replaced the distributor and gasket and then would run lean under partial load 15-16:1. So I decided to pull the harness and resolder my connections and solder in the boost solenoid that was installed on the day of tuning. Well, all said and done now the car runs ridiculously rich at idle. 9:1 if I get it to idle. The car doesn't stay running and seems to be at about 12:1 when revving. Also now the boost solenoid clicks constantly which reading is normal but did not do it prior when igniting on Engine off. Any ideas? Double checked injector order, map and TPs harness...etc.
Key Enzyme
Engine Management and Tuning
Mar 29, 2013 08:24 AM
