AFC hack questions
Old Oct 19, 2004 | 02:59 PM
5l-eater's Avatar
Default AFC hack questions
I built myself the AFC hack http://www.carolinahondas.com/...rpark
as temporary fuel managment until i can buy a burner. I did it because it looked interesting and fun to build. Well I have 1 question, what color os teh 5 volt refrence signal wire? I am using a set of 450cc injectors. Whenever I try to run the car it goes into limp mode. it idles well in limp mode, even with the 450cc dsm injectors. No matter what wire i hook up "V out" to, it throws a code 3, am I doing somethign wrong? i tried acelerating in limp mode and it pulls strong until 4000, then its weak as hell. is this normal? It runs pig rich, and its much slower then when I had an fmu and was runnign only 5 psi.
Right now it goes to 9 psi but then after 5000rpm goes back down to 5.
WTF is going on?
Old Oct 19, 2004 | 03:10 PM
Nick7's Avatar
Default Re: AFC hack questions (CRXdan1.6)
For stable 5V use 7805.
You Vout should be in 3V range.... maybe a tad higher, depending on injector size and how much you boost.
Reason for behaviour of yr car is that you've went into limp mode....
Old Oct 19, 2004 | 09:07 PM
5l-eater's Avatar
what is 7805?
And I just fried my ecu, trying diferent map sensor wires. I have a brown, white/yellow and red wire. Which one does it go to? and does it go to map sensor, or back to ecu?
jkan2005
Mar 31, 2003 01:43 PM
integranator
Mar 16, 2003 12:11 PM
iam7head
Mar 9, 2003 12:39 AM
asianspeed
Aug 22, 2002 09:12 PM
