afc hack problems
Old Jun 21, 2004 | 06:09 PM
1boostedcivic's Avatar
Default possible blown motor?
Just finished installing my turbo kit. I have been driving it around all day and it has been boosting very well. however after i left Shell's seafood tonight, the car wouldn't start as if my afc wasn't even on. I usually have problems starting the car because its so rich. my settings are -40 across the board, and my throttle points are 98,99. I also have the in and out settings at 6,6. it feels like its bogging and its just dumping fuel. it went from running great to ****. am i missing a setting on my safc or what?
EDIT: Possibly motor is blown. i checked the spark plug in cylinder 4 and its smashed. something must of hit it. cylinder 4 is dead.
Modified by 1zexxedcivic at 2:33 PM 6/22/2004
Modified by 1zexxedcivic at 9:08 PM 6/22/2004
Modified by 1zexxedcivic at 9:09 PM 6/22/2004
Old Jun 21, 2004 | 06:23 PM
stinker504's Avatar
Possibly bad injectors? Sounds like your hack settings are okay.
Old Jun 21, 2004 | 06:28 PM
Default Re: (stinker504)
i was thinking the same thing, but the car ran fine about 4 hours ago, its just dumping fuel. i mean i burnt a lotta gas on the way back. is it supposed to be hard to start the car with the hack?
Old Jun 21, 2004 | 06:33 PM
stinker504's Avatar
No, I have run the hack for almost a year now and it's started right up every time. What injectors do you have, and are they new or used?
Old Jun 21, 2004 | 06:35 PM
used 450cc dsm's, im running very rich with them though. too rich.
Old Jun 22, 2004 | 05:33 AM
Default Re: (1zexxedcivic)
not the hack guys motor is blown.
Old Jun 22, 2004 | 05:44 AM
TurboBumblBee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1zexxedcivic &raquo;</TD></TR><TR><TD CLASS="quote">not the hack guys motor is blown. </TD></TR></TABLE>
what happened?? what did you do to find this out?
EDIT: motor is blown. i checked the spark plug in cylinder 4 and its smashed. something must of hit it. cylinder 4 is dead.
Modified by 1zexxedcivic at 2:33 PM 6/22/2004</TD></TR></TABLE>
what do you mean smashed?
Old Jun 22, 2004 | 12:01 PM
Default Re: (TurboBumblBee)
i mean the spark plug is melted ill try to upload some pics a lil. later.
no compression at all in the 4th cylinder. the compression test showed 185, 195, 180, 10. the plug looks more melted. but the car seems fine, but when i take out the spark plug wire in cylinder 4, the car runs the same. maybe burnt valves? has anyone ever seen this before? cause if its that, then i'll just drop in some new valves and a headgasket and im good to
Old Jun 22, 2004 | 12:47 PM
bump
hondub
Mar 9, 2007 07:25 AM
pa2play
Jun 27, 2004 12:16 PM
specv5150
Jun 6, 2004 06:37 PM
Snoopy_cool
Apr 8, 2003 06:01 PM
integranator
Mar 16, 2003 12:11 PM
