AFC hack with DSM injectors, do I need a new fuel pump??
Like the topic says, do I need to get a walbro or other high performance pump, or will the stock one work. I am planning on running about 10 pounds of boost.
Re: AFC hack with DSM injectors, do I need a new fuel pump?? (Briman2021)
if its a stock sohc, then no you dont <u>need</u> it. i would still recommend it though. i got by with 208whp with a stock pump on a stock sohc, 50psi fuel pressure though.
Re: AFC hack with DSM injectors, do I need a new fuel pump?? (ham)
So I would be alright to run it with the stock pump at least for a while?
I also thought that the fuel pressure wouldn't be as much of an issue because I am not using a rising rate fuel pressure regulator?
Its only $100 and it takes like 30 minutes to install. Its just cheap insurance, Id get one
KevronsEG
01-07-2003 08:01 AM
