AFC Hack dont freak out!!!
Old Oct 22, 2003 | 05:17 AM
TOFU.man's Avatar
Default AFC Hack dont freak out!!!
I have searched and searched on this board to find out exact step by step instructions for how to insatall the afc hack. I know i need 440s and an SAF-C. I have an FMU right now and want to know everything i would need to do step by step on how to install this. Please help me guys i hate having this FMU it is so unreliable.
Old Oct 22, 2003 | 05:31 AM
VTC_CiViC's Avatar
Default Re: AFC Hack dont freak out!!! (B16AHondaSi)
Install the injectors. Install the SAFC. Set the trim accordingly (-40% to start off). Throw the car on a dyno w/ a wideband and adjust the trim accordingly.
EDIT: Don't forget to back the timing a good 2-3 degrees base.
Old Oct 22, 2003 | 05:43 AM
TOFU.man's Avatar
So i just get rid of the FMU install the AFC and injectors and hit the dyno thats it.
See i have a JRSC and i need to know if i need to get rid of the fuel relay that comes with it or what??
Old Oct 22, 2003 | 05:44 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16AHondaSi &raquo;</TD></TR><TR><TD CLASS="quote">So i just get rid of the FMU install the AFC and injectors and hit the dyno thats it.</TD></TR></TABLE>
Yes sir.
Old Oct 22, 2003 | 05:48 AM
TOFU.man's Avatar
Default Re: AFC Hack dont freak out!!! (VTC_CiViC)
So do i keep the fuel relay?
Old Oct 22, 2003 | 05:50 AM
rjardy's Avatar
I am not going to flam you but on this very page there is a huge info thread entitled "afc hack" it tells you how to do this, STEP BY STEP. What is this fuel relay your talking about? Allso with the hack you dont need an inline pump, a good high volume intank will be just fine.
Rob
Old Oct 22, 2003 | 05:55 AM
TOFU.man's Avatar
Default Re: AFC Hack dont freak out!!! (rjardy)
When you get a kit from JR it comes with a fuel enrichment relay and an FMU well I know i get rid of the FMU but i want to know about the realay. I have been to the dyno on the FMU and my a/f is like low as hell i am running way to rich why i dont know. I do not have and inline i have an intank walbro 255lph.
I wanna know if the relay goes with the FMU or does it stay?
Old Oct 22, 2003 | 05:59 AM
VTC_CiViC's Avatar
Ditch it. All you need is the injectors and AFC.
Old Oct 22, 2003 | 06:11 AM
MiraiZ's Avatar
Old Oct 22, 2003 | 06:18 AM
TOFU.man's Avatar
Well I hope you guys are right when it comes to that fuel enrichment relay cause it is about to come out.
Old Oct 22, 2003 | 06:42 AM
VTC_CiViC's Avatar
Wait a min.. is this for a JRSC??
Old Oct 22, 2003 | 06:46 AM
GreddySi99's Avatar
yes Lose the ******* relay!!!!!!!!!!!! ALSO you will have to relocate the map sensor so it will see boost and vacuum. to do this take it off of the TB and move it somewhere and zip tie it. then add a vacuum line from the intake manifold to the map sensor nipple and plug the hole on the TB somehow some way. That is it
Old Oct 22, 2003 | 06:49 AM
VTC_CiViC's Avatar
Default Re: AFC Hack dont freak out!!! (intercooledJRSC)
Yea I was just gonna say, if this is for a JRSC then you need to relocate the MAP sensor or you aren't going to fuel for boost, and that can be a problem!
Old Oct 23, 2003 | 05:13 PM
R0Y's Avatar
R0Y
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intercooledJRSC &raquo;</TD></TR><TR><TD CLASS="quote">yes Lose the ******* relay!!!!!!!!!!!! ALSO you will have to relocate the map sensor so it will see boost and vacuum. to do this take it off of the TB and move it somewhere and zip tie it. then add a vacuum line from the intake manifold to the map sensor nipple and plug the hole on the TB somehow some way. That is it</TD></TR></TABLE>
sorry.... do u care to explan why the map sensor needs to be relocated to see boost? I thought it will see boost if left were it was unless I misunderstand how it works??
right now I'm running my JRSC with both the relay and the VAFC and only with an upgraded fuel pump and the map sensor left where it was in the stock location
00BoostedGSR
Sep 25, 2007 07:07 AM
00BoostedGSR
Sep 24, 2007 10:17 PM
PreludeSiTdriver
Oct 15, 2004 10:24 AM
hybridb18
Apr 24, 2003 08:45 AM
