AFC HACK detonation at 9PSI
Maybe I am running to rich. I have my VAFC set at -35% for low rpm's and -34% for high rpms. And like I said, even when I am pinging my air fuel gauge reads rich (three-four green bars). I know this is probley a crazy question but can running too rich cause your car to ping????
What about a MSD BTM or bring your timing back a few degrees or more? I remember on my motor (still not turboed yet) I got pinging using 89 octane so I just brought the timing back 2 degrees and it is better. I'm thinking timing advance would do this so I guess bringing back the timing is worth a try.
Good to here that taking out timing solved your problem. I will go ahead and give that a try. I would rather not use the BTM if I do not have to.
If the dyno has a wideband it would be the best place to determine the problem. You are either pinging from to much advance or from a lean mixture. You should be able to add more fuel with the AFC with out triggering the CEL.
Thanks guys.!! I uped my fuel pressure to 38psi (AEM FPR), and I took 2 more degrees of timing out (total of 4degrees retard), and the car runs great! I went out last night and did a couple of passes at 9psi and the pinging is gone. It pulls really hard and the air fuel gauge shows green all the way to red line. Monday I am going to R&D dyno to get it tuned and I will post the results then. Thanks again for the help.
ITR.#1446
Mar 25, 2004 01:02 PM
ITR1071
Feb 19, 2003 10:07 AM
