AFC with 370s
Old Aug 25, 2009 | 01:00 PM
Y4 Warrior's Avatar
Default AFC with 370s
OK guys, ive been doing a little bit more research.
Now the injectors im going to use will be from a CA18DET (hoping they fit). 370cc, top feed, low imp. So i still need a resistor box. Now, since ill be scaling the AFC down lower than typical 450s, going to start around -25% -30%, does that mean i wont be able to run as much boost. since the AFC is scaled lower, would i throw a cel if i run like 8-9psi with -30%?
The reason behind using CA18DET injectors is quite simple. I know there are heaps to find in australia, going for a cheap price, & since i only plan to run under 200whp, should be quite adequate for my needs. 450 DSM injectors, i would need to buy overseas, counter in exchange rate & shipping, they end up costing me more, so sourcing injectors locally will save me alot of time & money. However, i cannot confirm for sure yet, Ive been told Mitsu Lancer GSR injectors are 450, but i have to confirm that...
I will explain why im FORCED to run an AFC hack in a later post, just dont have time right now, i copied the above info from another forum where i posted the same q. Thanks....
BOOSTEDC4
Jan 28, 2006 05:52 AM
forcefedferio
Dec 25, 2005 12:20 PM
BlackB18CTeg
Apr 2, 2003 07:40 AM
Fatty_1775
Jan 9, 2003 08:28 PM
B17aTrbo
Sep 16, 2002 08:12 PM
