aeromotive stealth and wiring concerns
ok so i just got my new pump in the mail and installed it and it works my question is after reading several post on here people keep talking about the wiring and it needing to be bigger so i checked mine out and sure enough running i only have about 12 volts at the connecter
now in one thread that i saw about adding a relay and adding new wiring said to use the stock car wiring to terminal 86 on the relay i get all that my actual question is what about the wiring in the tank i left that factory nobody has mentioned changing that is that ok?? its a 2000 civic si if that makes any difference also one last note my goals arent to high im only hoping for about 400 hp ??
this is the link to how i want to wire it up https://honda-tech.com/forums/showpo...7&postcount=41
