aeromotive quesiton
Old Feb 27, 2002 | 03:09 PM
SiRkid's Avatar
Default aeromotive quesiton
will the aeromotive fuel pressure regulator fit my 00 Si(R) stock fuel rail?
ive read and searched and i have this question.
why would i need to change my stock fpr to say the aeromotive(which is what i will use) when boosting? ive never gotten a clear answer.
thanks
should i replace my stock fuel rail????or will it be sufficient enough?
not boosting over 8psi for a while.
[Modified by SiRkid, 12:14 AM 2/28/2002]
Old Feb 27, 2002 | 03:16 PM
D-SPEED's Avatar
Default Re: aeromotive quesiton (SiRkid)
a week or two ago there was a very extensive post on this. If you can find it, I am pretty sure it will answer all your questions.
Old Feb 27, 2002 | 03:20 PM
SiRkid's Avatar
Default Re: aeromotive quesiton (D-SPEED)
i looked!
maybe im blind.
what would be the part # from summit racing for the aeromotive for me?
i= stupid and cant figure out.
note:Sorry to all...im sooo tired and dumb lately
SEFIxCivic's Avatar
it wont directly fit on to your stock fuel rail. you'll have to take off the stock regulator and have that port on the rail tapped for pipe thread and find the appropriate AN adapter. From there you can run a line to the aeromotive.
From my understanding the stock regulator does not increase fuel pressure after it has reached 0 vacuum. While boosting the injectors must overcome manifold pressure, and since the regulator is not compenstating, you in turn get less fuel to your motor. The Aeromotive is supposed to be a true 1:1 boost referenced regulator + its adjustable.
Old Feb 27, 2002 | 07:07 PM
93LSivic's Avatar
I think this is the post you wanna check out. Just read through it last night.
https://honda-tech.com/zerothread?id=121452
Old Feb 27, 2002 | 07:09 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: aeromotive quesiton (93LSivic)
The part # you need is the Aeromotive 6an kit AEI-13109.
art
Old Feb 28, 2002 | 06:04 PM
SiRkid's Avatar
Default Re: aeromotive quesiton (Arturbo)
thanks everyone!
sorry for my tiredness
GT500FTW
Jul 14, 2015 10:39 PM
dylaxiin
Dec 2, 2011 03:27 AM
jdmboy94
Dec 25, 2008 05:01 PM
01_ITR
Jul 21, 2008 03:19 PM
Schister66
Jan 5, 2006 06:37 PM
