Aem wideband help
Old Dec 20, 2004 | 09:53 AM
adictionbass's Avatar
Default Aem wideband help
Whats up guys, i picked up an AEM Eugo wideband a litle bit ago and was wondering about the wiring. I looked all over the place and couldnt find anything (someone is probably going to find it in a min) .
There is basically two harnesses coming out - one six wire which goes to the sensor (red black green orange white and brown) then the other harness is four wires. (red, black, white, blue). What are each of the wires on the second harness for? I assume ones poistive and one is negative. Doesnt one have to be the remote wire? Whats the last one for? And can you/how do you hook this up with a hondata system?
Thanks in advance for any help, just a diagram should help, but i couldnt find one.
Old Dec 20, 2004 | 10:54 AM
Default Re: Aem wideband help (adictionbass)
anyone know where to find the diagram for it...
Old Dec 20, 2004 | 11:48 AM
BlueSi2k's Avatar
Seems like the aem forum is down...got it off my hard drive
http://www.ic.sunysb.edu/Stu/j...s.pdf
Old Dec 20, 2004 | 11:56 AM
Default Re: Aem wideband help (BlueSi2k)
your the man
Old Dec 20, 2004 | 12:02 PM
red: power
black: ground
white: 0-5 volt output
blue: serial output
for anyone looking for info
Anyone know how to or if you can use this with hondata and not worry about using the stock sensor?
Modified by adictionbass at 9:19 PM 12/20/2004
Old Dec 23, 2004 | 06:08 PM
BoostedJeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">red: power
black: ground
blue: serial output
Modified by adictionbass at 9:19 PM 12/20/2004</TD></TR></TABLE>
I have the UEGO and I was wondering how the serial works, being that there isnt any software that comes with it. Does it automatically sense the wideband???
Old Dec 23, 2004 | 06:48 PM
TurboLSVtecTeg's Avatar
Default Re: Aem wideband help (BoostedJeff)
If you got the wideband new. It should have the info in the box with it. I think I might have it in PDF format. Ill check real quick.
Sal
Old Dec 23, 2004 | 09:45 PM
Default Re: Aem wideband help (TurboLSVtecTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLSVtecTeg &raquo;</TD></TR><TR><TD CLASS="quote">If you got the wideband new. It should have the info in the box with it. I think I might have it in PDF format. Ill check real quick.
Sal</TD></TR></TABLE>
thanks, that would be nice
Laojoeturbo
Jan 12, 2010 10:21 PM
[Ennis_D]
Jan 7, 2010 12:52 PM
Blk99ek
Sep 11, 2009 07:04 AM
b20beast978
10
Jul 20, 2007 08:15 AM
CustomX113
Aug 24, 2006 09:59 PM
