AEM tunners need some help
Old Dec 18, 2006 | 02:10 PM
JDMCRX's Avatar
Default AEM tunners need some help
Im doing some work on this skyline we have AEM on it and it keeps flooding itself. Ive changed the injector size from 440cc to 1000cc now will the AEM change anything or will i have to change the maps manualy.
Also how do i change the scales?
Old Dec 18, 2006 | 02:12 PM
tony1's Avatar
Default Re: AEM tunners need some help (JDMCRX)
You will probably actually have to tune the car rather than just changing the injector calibration.
Old Dec 18, 2006 | 02:17 PM
JDMCRX's Avatar
Default Re: AEM tunners need some help (tony1)
thats what i thought so im going to have to take fuel out of the mapps on start up
Old Dec 18, 2006 | 04:38 PM
alpha's Avatar
Start with the Injector Changes on the fuel map. After that retune
Old Dec 18, 2006 | 05:09 PM
Synapse Motorsport's Avatar
Default Re: AEM tunners need some help (alpha)
Do you have a wideband in the car? Make sure you pick the right batt offset in the injector wizard and then rescale the injector and pressure. Changing from 440's to 1000's is going to require tuning immediately
Old Dec 18, 2006 | 05:42 PM
JDMCRX's Avatar
Default Re: AEM tunners need some help (Synapse Motorsport)
I tried the wizard says it will not work . Im gonna update it and retry
Old Dec 18, 2006 | 05:59 PM
Jared's Avatar
If you are this lost you might wanna consider having someone tune the car.
Old Dec 18, 2006 | 06:26 PM
JDMCRX's Avatar
Default Re: (Jared)
The car is getting tunned i just want to start it Im not good with the AEM system.
The problem im having is i can not start the car ive modified the maps and so forth. But the ecu and the crank sensor needs to be verified first. I just wanted to start the car check for leaks and **** but i guess well do that at the dyno.
The wizard will not work for me it says contact AEM
Old Dec 18, 2006 | 06:29 PM
JDMCRX's Avatar
Default Re: (JDMCRX)
Just tried to run the setup wizard and i get this
ERROR
COULD NOT FIND AEM CONFIGURATION FILE. CONTACT AEM FOR ASSISTANCE
Werid i tried on 3 different laptops and i get the same message
Old Dec 18, 2006 | 06:38 PM
tony1's Avatar
Guess you gotta contact AEM for assistance. lol
Old Dec 19, 2006 | 05:04 AM
Ovrbst_T66's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Guess you gotta contact AEM for assistance. lol</TD></TR></TABLE>lol assistance from aem...good luck.Hell try to post in the forums, you may get a reply back sometime in the new year.JDMCRX Best thing for you to do is to take it down to a shop that can tune it for you.
Old Dec 19, 2006 | 09:15 AM
wHOAlly's Avatar
Default Re: (danny_t66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny_t66 &raquo;</TD></TR><TR><TD CLASS="quote">lol assistance from aem...good luck.Hell try to post in the forums, you may get a reply back sometime in the new year.JDMCRX Best thing for you to do is to take it down to a shop that can tune it for you.</TD></TR></TABLE>
the forum isnt intended for tech support, its more of a meeting ground for tuners to collaborate, share ideas, get tips, etc, its also for updates and happenings inside AEM electronics.
if u need tech support, call the tech line, if its busy leave a message, if u dont get a call back, then u called the wrong extension, lol.
310-484-2322 x303
frostwhite_92
Engine Management and Tuning
11
Sep 6, 2012 07:27 AM
11psiTurboSI
Apr 7, 2005 04:55 PM
ladysman
Honda S2000
May 12, 2004 07:38 AM
eg2turbo
Feb 22, 2003 10:49 AM
2K_TEG
Jul 1, 2002 04:39 PM
