AEM fuel rail
Old Feb 28, 2002 | 12:27 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default AEM fuel rail
What size AN size is used for the ports where the nos jets go?
Refer to this pic where the plugs are at.
immortal's Avatar
Banned
Default Re: AEM fuel rail (Arturbo)
lemme check i have the box here.....
1/8" npt
Old Feb 28, 2002 | 12:28 AM
immortal's Avatar
Banned
Default Re: AEM fuel rail (immortal)
btw wtf
that fuel rail looks nothing like the one i have for the gsr
is that the h22 one?
Old Feb 28, 2002 | 12:30 AM
Arturbo's Avatar
Better than steak
25 Year Member
Damn that was fast!! Ok, now the side ports can be either be a -6 or -8AN, correct??
Thanks.
Old Feb 28, 2002 | 12:33 AM
immortal's Avatar
Banned
it doesnt say but i'm pretty sure thats correct
Old Feb 28, 2002 | 12:45 AM
Arturbo's Avatar
Better than steak
25 Year Member
Yes, I stole that pic from Mark95accord, and I think he has a prelude.
art
Old Feb 28, 2002 | 12:56 AM
SEFIxCivic's Avatar
i think the sides are a pipe thread
Old Feb 28, 2002 | 01:02 AM
immortal's Avatar
Banned
Default Re: AEM fuel rail (SEFI8LOxCivic)
High Volume Fuel Rail
AEM High Volume Fuel Rails are CNC machined from 6061 T-6 billet aluminum and feature a 1/2-inch fuel bore capable of flowing enough fuel to support most high-performance engines. This larger bore also dampens the back pulse created by oversized injectors in high-output applications. The AEM fuel rail also works perfectly with stock injectors. Each fuel rail includes an additional port for the installation of a nitrous set-up or external fuel pressure gauge. The ends of the fuel rail are tapped to accept either -6 or -8 line and a custom fitting allows for the use of the stock fuel hose. AEM’s High Volume Fuel Rail kit includes new injector O-rings, fuel line fittings, comprehensive installation instructions and AEM decals.
Old Feb 28, 2002 | 01:15 AM
Arturbo's Avatar
Better than steak
25 Year Member
Thanks imortal. I found the same info on AEM's website, but I bought some fitting to fit the stock rail but I changed my mind. Now I need to buy more expensive fittings. But oh well, it'll sure look nice.
art
Old Feb 28, 2002 | 01:49 AM
SEFIxCivic's Avatar
Whoops, i guess i learn something new everyday. i've never heard of a fuel rail configured like that before.
Old Feb 28, 2002 | 01:54 AM
immortal's Avatar
Banned
bling bling
Old Feb 28, 2002 | 02:00 AM
SEFIxCivic's Avatar
101% That's a first if i've ever seen one! is that manifold going on your ride? when is it going to be done?
Old Feb 28, 2002 | 02:23 AM
immortal's Avatar
Banned
i'm hoping for my car to be finished by mid march - early april
my block is at golden eagle right now
my head is at portflow
http://immy.home.attbi.com/integra.html for a full mods list
i STILL cant figure out what turbo i want to run :/
Old Feb 28, 2002 | 02:40 AM
SEFIxCivic's Avatar
sounds like an awesome setup. i had thoughts of building my car up also, but ever since i spun a rod bearing on my b16, i've had second thoughts and decided i'm going to concentrate on finishing school.
do you have a majority of your turbo parts already? because one of my friends who also quit racing is selling an XS GTS sized intercooler, XS TO4X full T4, and revhard Equal length manifold (the one kenny tran has). Are you interested?
i think for your car you should definately go to a straight T4.
Old Feb 28, 2002 | 02:50 AM
boosted3g's Avatar
I know for a fact the ends of the rail are 6AN. I measured them yesterday due to the fact i am having problems trying to get a rail and regulator combo. If you do get the AEM regulator its a strange fitting for the return. I think its 9/16-18 or something like that. If you dont use one that rail looks to be tapped for 1/4 npt or 4an but im not positive.
Old Feb 28, 2002 | 03:31 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: AEM fuel rail (boosted3g)
Well according to AEM's website, you choose what fitting you want. For example, if you have stock fuel line you can still use the 12mmx1.25 banjo fitting. Or you can change it out to a -6 or -8 fitting.
art
Old Feb 28, 2002 | 02:07 PM
boosted3g's Avatar
I honestly dont know why they say that. The threads are definantly 6an. I use all an fittings and i rechecked them and they are -6. They also say that about there regulators and they are not even an threads.
Old Feb 28, 2002 | 02:15 PM
paulzy's Avatar
hey art, check out this link on a custom fuel rail.....looks simple enough
http://www.sdsefi.com/techrail.htm
Old Feb 28, 2002 | 02:59 PM
HXMan's Avatar
.......and AEM decals.
A must have for the serious racer!
Old Feb 28, 2002 | 03:17 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: AEM fuel rail (HXMan)
At this point, Im to lazy to fab up a fuel rail. I already purchased the AEM..
art
Old Feb 28, 2002 | 03:40 PM
immortal's Avatar
Banned
art
bling bling
now you need the aem wire cover & fuel filter like me
show points plz !
Old Feb 28, 2002 | 04:04 PM
Arturbo's Avatar
Better than steak
25 Year Member
Well, Im painting it flat black.. so no show points for me, or negative points shall we say. I'll get worst of show awards..hehe
art
Old Feb 28, 2002 | 04:47 PM
AlphaKennyWun's Avatar
arturbo,
I know you WERE (past tense) going to modify your stock fuel rail to use with aeromotive fpr. What happened man? Now I am at it alone.
I need to know the size to order the AN flare to metric adapter for the stock rail.
-6AN/XXmm
or is the stockrail an AN fitting?
yours is still gonna look like this right?
thanks for the pix Mark
[Modified by SO3Burner, 1:49 AM 3/1/2002]
[Modified by SO3Burner, 1:50 AM 3/1/2002]
[Modified by SO3Burner, 1:52 AM 3/1/2002]
Old Feb 28, 2002 | 05:09 PM
lucas569's Avatar
Default Re: AEM fuel rail (SO3Burner)
art on the aem rail how does the hole that the stock regulator would have gone in get covered? is it pre-threaded?
Old Feb 28, 2002 | 05:27 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: AEM fuel rail (lucas569)
My AEM isnt here yet. But the threaded stud on the the stock fuel rail is 12mm x 1.25 and I was gonna thread the hole, or port, where the stock regulator was at. But my order from FREAKIN Baker's never showed up, so I got tired of waiting and ordered from Summit and the rail from Ben.
art
