AEM EMS hell Begins...
Old Jun 5, 2003 | 07:10 AM
  #26
legendboy's Avatar
Default Re: AEM EMS hell Begins... (Tinker219)
fo shizzo, I'm intrested in reading that thread but I don't have access to it. I am a member of the aem forum tho. Maybe one of you could copy and paste!
Old Jun 5, 2003 | 07:22 AM
  #27
ekb18c's Avatar
If you had hondata you probably would be boosting by now.
Old Jun 5, 2003 | 07:37 AM
  #28
TurboSedan's Avatar
New User
Default Re: AEM EMS hell Begins... (ekb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c &raquo;</TD></TR><TR><TD CLASS="quote">If you had hondata you probably would be boosting by now. </TD></TR></TABLE>
This is why I chose Hondata! To quote Art, K.I.S.S.!!!!
Old Jun 5, 2003 | 07:49 AM
  #29
metal-x's Avatar
Default Re: AEM EMS hell Begins... (TurboSedan)
here is the post although not editted
Lowell Foo
High School Poster
Vehicle: 1994 Toyota Supra Twin Turbo, 6 Speed Posted: Wed May 07, 2003 6:18 pm Post subject: Another flash ROM gone bad
30-1020, 96 GS-R turbo.
Car drives onto the rollers no problem, shut off and strap it down, go to restart the car and nothing. No ECU comms, no fuel pump relay, zip. Plug in the stock ECU (always carry your stock ECU in the car) and the car fires right up, although running a bit rich with 550cc injectors.
At this point we're pretty **** off because we moved another customer off to do "a few quick pulls" on this Integra and guys want to go home early today to watch the hockey game. Tried the firmware recovery program several times with no luck. So to make a short story shorter, I opened the EMS, flashed the 0.94 fin file straight onto the chip and the car fired right up after uploading the map.
Will an AEM engineer please explain what is going on here, and what will be done about it?
_________________
-Lowell
http://www.lr-racing.com
Back to top
TDtrader
Community College Poster
Vehicle: 1993 Toyota Supra Posted: Thu May 08, 2003 2:53 am Post subject: Re: Another flash ROM gone bad
How do you open up the EMS and flash the .94 fin file straight onto the chip? Sounds like it might be a useful recovery technique...
Back to top
BLKMGK
Freaking Hardcore
Vehicle: 1995 Toyota Supra Twin Turbo, 6 Speed Posted: Thu May 08, 2003 5:15 am Post subject: Re: Another flash ROM gone bad
You've got to have an EEPROM programmer handy and some electronics know how.
Something is corrupting the datastream to the ECU from the laptop. AEM put some code in the .94 release(s) to try and stop this and may have put some in even earlier, as you've seen it's not a perfect fix. I know in at least one case they found some sort of funky gorund loop between the serial laptop connection and the laptop that caused the laptop to draw power through the serial gorund and fry a resistor on the AEM board but that doesn't sound like the problem here. AEM has collected several toasted chips in order to try and figure this out and my fingers are crossed that 1.0 will finally seal the deal here. From my conversations with AEM I know this is HIGH on their list of fixes - like #1 - but they've not been able to easily duplicate it. Without being able to duplicate it it's going to be REAL hard to solve
_________________
Http://www.blkmgk.com
morejunk4me@hotmail.com
Please do NOT crosspost.
NO CAI info found here
Everything I know I learned by breaking something first!
Back to top
JW
Site Admin
Vehicle: 2001 Ford V8 Posted: Thu May 08, 2003 6:39 am Post subject:
We are fairly confident we have found the problem with the EEPROMs, we are doing testing on it now to make sure we haven't un-fixed something else in the process. Version 1.0 will have the new EEPROM fix and should be available very soon. We are doing final conformation and getting the details worked out of a conversion utility for the older calibration files.
_________________
The only reason for time is so that everything doesn't happen at once.
- Albert Einstein
Back to top
Lowell Foo
High School Poster
Vehicle: 1994 Toyota Supra Twin Turbo, 6 Speed Posted: Thu May 08, 2003 12:25 pm Post subject:
Thank you for updating us on this. One guy here with an 1100 has had his flash rom blank out 3 times and won't put the EMS back in his car until it's fixed.
_________________
-Lowell
Back to top
BLKMGK
Freaking Hardcore
Vehicle: 1995 Toyota Supra Twin Turbo, 6 Speed Posted: Thu May 08, 2003 2:52 pm Post subject:
JW - can you share any details on what was happening? Is it somehting we can avoid doing in the meantime?
_________________
Old Jun 5, 2003 | 08:50 AM
  #30
Tinker219's Avatar
Default Re: AEM EMS hell Begins... (metal-x)
Im just st00pid. I hate 15amp Ignition fuses that blow almost indescretely.
It works...haha, thanx guys...(walking away with sulky shoulders, embarrased as hell)
Old Jun 5, 2003 | 10:07 AM
  #31
underpressure02's Avatar
Its all good. Do not give into Hondata When I was having all my problems everyone was saying go hondata. I was so close to going but I stuck with it and figured out the problems and had the car running perfectly the day it got stolen. I am glad I could help the thieves get a nice running car. Bastards. BUt seriouly stick with the AEM. I would go back to version .89 for the least amount of headaches but if you like to tinker and learn about the bugs in .94 stay with that version. Just make sure you have another car to drive when and if the aem decides to be a b!tch.
Old Jun 5, 2003 | 12:02 PM
  #32
legendboy's Avatar
Default Re: AEM EMS hell Begins... (underpressure02)
Your getting very very sleepy...... I see a hondata in your future lol
Modified by legendboy at 10:38 AM 6/6/2003
Old Jun 5, 2003 | 01:36 PM
  #33
Tinker219's Avatar
Default Re: AEM EMS hell Begins... (legendboy)
haha...will do. Im going to use v.94 until 1.0 comes out. Then its all over from there. I just have to fill up my trans, finish some piping, hook up guages, and the turn the biotch over! Cant wait
jonwtsb
Engine Management and Tuning
Sep 26, 2011 01:07 PM
hotboykemarm
Jan 14, 2011 09:59 AM
skunk2allmotor
Mar 31, 2010 05:02 AM
Universal Magnetic
Aug 10, 2003 01:17 PM
