AEM EMS hell Begins...
Old Jun 3, 2003 | 07:39 PM
Tinker219's Avatar
Default AEM EMS hell Begins...
OK, need help with the EMS, mase, falcongsr, any others can you help me?
Heres the deal:
Installed v.94 on the laptop.
plugged into computer and ecu to upload, click "connect" and the status box comes up, but nothing happens after that.
Car is off, I have power to the ECU. It says "Comms initiated" in the status box, so Im sure the computer is set-up for the connection. Am I another victim of EMS hell, or am I just stupid?
Old Jun 3, 2003 | 08:11 PM
Greaser's Avatar
Default Re: AEM EMS hell Begins... (Tinker219)
disable any palm pilot or wireless mouse. disable ANY program that runs off a serial port.
i went through this with my TEC II and motec lambda meter
Old Jun 3, 2003 | 08:14 PM
Tinker219's Avatar
Default Re: AEM EMS hell Begins... (Greaser)
hehe...well, Im going to try to re-start the computer tomorrow. It was on stand-by for awhile, so hopefully that does it. any other suggestions? oh ya, nothing else is hooked up...
Old Jun 3, 2003 | 08:15 PM
metal-x's Avatar
this a new or used unit?
Old Jun 3, 2003 | 08:17 PM
Tinker219's Avatar
Default Re: AEM EMS hell Begins... (metal-x)
it was never used, but it is a "used" unit. Boomslang on here sold it to me. he never used it, so its still "new". persay
Old Jun 3, 2003 | 08:24 PM
Greaser's Avatar
let me clarify, but dont take this wrong
just because something is not plugged in does not mean that com port is being addressed to some other device. A modem could be on com 1 and com 2 could be free.
control panel
modems
diagnostics
post what it says.....
also, have you tested the port with some other device to show its functioning? the ports may be disabled in your BIOS menu.
Old Jun 3, 2003 | 08:27 PM
salt's Avatar
are you sure the EMS has power ? Can you hear the fuel pump go for a second when you turn the car on ? did you try com1 and com2 ?
mine had to be sent back, I bought it used but new as well.
Old Jun 3, 2003 | 08:35 PM
UtahRockabilly's Avatar
Default Re: AEM EMS hell Begins... (salt)
I was under the impression that the EMS plugged into the serial port?
in that case its almost always going to be a com2 or 3 but never a com1 thats always reserved for modems
like he said make sure that the serial port is enabled in bios and make check the connection on the serial port see if its even communicating
Old Jun 3, 2003 | 08:42 PM
Tinker219's Avatar
Default Re: AEM EMS hell Begins... (UtahRockabilly)
ok, ill try everything tomorrow. Im too tired right now.
I know the EMS has power, because I tested the power wire in the harness, and its hot.
Fuel pump is unplugged, because my fuel system is not yet assembled completely. I just wanted to see if this damn thing worked, because Im starting up tomorrow or the next day, and wanted to know if I needed to get my old "hack" **** ouf of the closet...
Old Jun 3, 2003 | 08:52 PM
if all else fails you can try the AEM board as well good luck
Old Jun 3, 2003 | 10:24 PM
BoostedSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 &raquo;</TD></TR><TR><TD CLASS="quote">OK, need help with the EMS, mase, falcongsr, any others can you help me?
Heres the deal:
Car is off, I have power to the ECU. It says "Comms initiated" in the status box, so Im sure the computer is set-up for the connection. Am I another victim of EMS hell, or am I just stupid?</TD></TR></TABLE>
car should be set on the "ON" position. If you already did that, make sure you have it set to the right port. If you dunno the port number, just go through all of them.
Old Jun 4, 2003 | 04:12 AM
Tinker219's Avatar
Default Re: AEM EMS hell Begins... (BoostedSi)
k...well, ill try it with the car on and off. ive heard it works with both, we will see I guess.
updates shortly.
The AEM board takes FOREVER. Iv ehad this on here for 8 hours and 13 replies. Itd take a year to do that over there
Old Jun 4, 2003 | 04:47 AM
GreddySi99's Avatar
I am NO expert but I have heard V.94 has had some problems. Could this be his issue???
Old Jun 4, 2003 | 05:22 AM
echo999's Avatar
New User
What are you expecting to happen after you connect?
Nothing pops up.
You need to bring up some menus/parameter windows MANUALLY to see any
real activity after you connect. There are no standard windows that will pop up
after you connect.
Old Jun 4, 2003 | 05:39 AM
Mase's Avatar
Default Re: AEM EMS hell Begins... (echo999)
Ok check out this link
http://forum.aempower.com/bbs/...85b39
Also, I cant remember back in the day when i first got my EMS.
But try this, Go to ECU: In System Programming: and choose the .94, If still nothing try .89 or a different version....
and let me know what happens.
Also, Hit me up on PM cuz it could be one of many things and maybe not the actual EMS.....
Old Jun 4, 2003 | 05:51 AM
Tinker219's Avatar
Default Re: AEM EMS hell Begins... (Mase)
Internal modem is listed on Com 3...talking to mase on AIM...
Old Jun 4, 2003 | 06:05 AM
len's Avatar
len
Some more hints:
Check ends of the Serial Cable and make sure all pins are there.
Check the Serial Cable itself for any damage or crinks.
If possible swap out a different serial Cable.
Make sure all connections to the EMS "snaps" in. Do not force the plugs in.
Make sure no wire(s) from the harness is loose or crimped or cut.
Make sure your laptop is compatible with the program. (AEM's website as a list of system requirements.)
Make sure any power saving features or screen savers are turned off.
If at all possible, try to plug the laptop to a wall outlet. *This will save you alot of headaches trying to run base maps and tinker with startup and idle*
Make sure you don't have any programs that will address the Serial Port on.
In fact disable any programs from startup menu or go to "run" "msconfig" "startup" and turn everything off.
One last helpful hint. If you get it working and start the car up and it runs for about 30 seconds and shuts off, check the TPS Voltage Value.
Old Jun 4, 2003 | 11:00 AM
legendboy's Avatar
Default Re: AEM EMS hell Begins... (len)
You can always trade me your ems for my hondata 3b w/extras! lol
Old Jun 4, 2003 | 12:43 PM
underpressure02's Avatar
Let me start off by saying go back to version .89 before you do anything. Version .94 is a nightmare. I had so many wierd issues with the unit when I upgraded to version .94. You can read my pains on the aem board. Not sure where you are in your process with this problem but feel free to im me. I maybe able to help.
Old Jun 4, 2003 | 01:01 PM
Tinker219's Avatar
Default Re: AEM EMS hell Begins... (legendboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy &raquo;</TD></TR><TR><TD CLASS="quote"> You can always trade me your ems for my hondata 3b w/extras! lol</TD></TR></TABLE>
done. where do you want it sent?
Anyway, We ran the FIN recovery, and no good. So Im assuming the Eprom is down. Mase and I couldnt figure it out. Nothing worked for any version. I have power to the ECU, my laptop is configured correctly, and my patch cable is perfectly fine.
Old Jun 4, 2003 | 01:03 PM
metal-x's Avatar
I don't think warranties are not Tranfereable if you buy it used
Old Jun 4, 2003 | 05:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x &raquo;</TD></TR><TR><TD CLASS="quote">I don't think warranties are not Tranfereable if you buy it used</TD></TR></TABLE>
Yeah they are send it back. They will fix it.
Old Jun 5, 2003 | 04:51 AM
Tinker219's Avatar
Default Re: AEM EMS hell Begins... (underpressure02)
Cool, thanx man. My condolenses go out you you and youre car too btw. That thing was badass
Old Jun 5, 2003 | 05:39 AM
Here is a post on the AEM board that you may want to read. It is about the Eproms going bad on the AEM units.
http://forum.aempower.com/bbs/viewtopic.php?t=3441
Old Jun 5, 2003 | 05:44 AM
Tinker219's Avatar
Interesting. Anybody want to flash a v.94 Vin file for me? Im seriously debating swapping this pos for Legenboys Hondatas 3b. At least I know itll work...
