AEM EMS going crazy
Old May 24, 2004 | 04:44 PM
integra-modder's Avatar
Default AEM EMS going crazy
its reading 4.99 volts for the TPS, the TPS wiring hasnt been messed with
its getting 10.84 at the map sensor with the engine off
.7 for air and coolant temps when its 80 outside...
What the hell did I do, anyone know?
Old May 24, 2004 | 05:18 PM
Muckman's Avatar
Moderator in Chief
Default Re: AEM EMS going crazy (integra-modder)
Dude you have more problems with that thing lol
Try recalibrating the throttle range. I usually use the wizard then take .02v off the TPS min
Old May 24, 2004 | 07:28 PM
Default Re: AEM EMS going crazy (Muckman)
Check this screen shot out:
http://filebox.vt.edu/users/po...S.jpg
My sensors are all going awry, I cant think of anything I could have done to **** the EMS like this...
Old May 24, 2004 | 08:40 PM
JDogg's Avatar
check the option for idle switch input, make sure its set to always off, for some reason on the honda box's if you set it to on it makes everything get all wacky.
Old May 25, 2004 | 04:50 AM
Default Re: AEM EMS going crazy (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">check the option for idle switch input, make sure its set to always off, for some reason on the honda box's if you set it to on it makes everything get all wacky. </TD></TR></TABLE>
Where is this controlled from?
Old May 25, 2004 | 09:59 AM
JDogg's Avatar
in the menu goto idle_advanced idle_advanced idle (should have a T beside it) a bunch of windows will come up, look for the idle switch input
Old May 25, 2004 | 10:13 AM
SOHFAST94's Avatar
Not that I'm a wizard on the AEM becasue I'll be the first to admit that I'm not although you may want to check the EEprom.
Old May 25, 2004 | 04:22 PM
Default Re: AEM EMS going crazy (SOHFAST94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHFAST94 &raquo;</TD></TR><TR><TD CLASS="quote">Not that I'm a wizard on the AEM becasue I'll be the first to admit that I'm not although you may want to check the EEprom.</TD></TR></TABLE>
I contacted Mitch at EMS and he said it sounded like there might be a problem with the box so he game me an RGA # and I sent it to them...
Old May 25, 2004 | 05:50 PM
SiRkid's Avatar
Old May 25, 2004 | 06:35 PM
Alstare's Avatar
Default Re: AEM EMS going crazy (SiRkid)
I just answered this same question on the aem board 3 mins ago...
Did you check that idle switch option first before shipping it out?
Tends to be a common mistake..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRkid &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
yea, thats what i thought...
Old May 25, 2004 | 06:36 PM
Default Re: AEM EMS going crazy (Alstare)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alstare &raquo;</TD></TR><TR><TD CLASS="quote">I just answered this same question on the aem board 3 mins ago...
Tends to be a common mistake.. </TD></TR></TABLE>
nope, got the reply too late on where to locate it...but I loaded up the stock 1010 Integra calibration, so I think it shouldnt have been checked...
Aradin
Sep 10, 2014 08:52 AM
SilverWarrior
21
Mar 14, 2008 07:09 PM
ericstambaugh07
Jan 20, 2007 01:52 AM
CA6VTEC
Sep 14, 2004 05:57 PM
HONDABOND
21
Oct 30, 2003 06:57 AM
