aem cam gears with FMAX turbo
New User
what should be the best setting with the FMAX turbo kit with AEM cam gears. i know it has to be retarded, but which is the best setting done to make the most power for a daily driver? thanks
its for a 5th gen lude.
[Modified by ELUD THS, 11:18 PM 8/14/2002]
New User
Re: aem cam gears with FMAX turbo (ekb18c)
thanks for the imput, just curious if any turbo ludes had cam gears with good setting that wored out ok, the dyno here charges close to 40 an hour.
Re: aem cam gears with FMAX turbo (ELUD THS)
every engine is going to be different dude, esp. with a turbo. go get 2 hours worth of dyno time and you'll never have to do it again unless you make a drastic change.
Re: aem cam gears with FMAX turbo (dlplayboy)
40 an hour is like robbing the dyno shop. that is beyond cheap. if you go there and dyno it...id say only one hour, maybe you could gain 5-10hp which is a lot of hp for 40 bucks. dont think of it as a loss of 40 bucks...its like buying a go fast good...Mike
New User
Re: aem cam gears with FMAX turbo (ninesecrx)
thanks for the tips. i ll double check the amount of $$ for dyno time. i could be wrong.
