adjusting internal wastegate
Old May 18, 2009 | 02:43 PM
odishaw's Avatar
Default adjusting internal wastegate
k guys so i have a gt2871r turbo and im looking at the internal wastegate on the turbo and im trying to understand how adjusting it works.. if you undo the nut towards the wastegate it should increase the boost, but how does the bar move over back up to the nut? someone shed some light if possible.. thanks
Old May 18, 2009 | 03:03 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: adjusting internal wastegate
shorten the rod, more boost
lengthen the rod, less boost.
if you shorten the rod, the less the gate can open, thus making more boost.
Old May 18, 2009 | 04:23 PM
odishaw's Avatar
ok i understand how that works, but from what i see i just loosen the nut, but how do i get the sleeve thats covering the threads to get back up to the nut?
Old Mar 17, 2011 | 11:25 PM
jonesEK's Avatar
TTT
Old Mar 18, 2011 | 08:40 AM
darkvader0's Avatar
USually have to remove the retaining clip that holds the rod to the flapper valve. Then the whole rod is threaded to you tighten it/loosen it by rotating the whole rod.
Old Mar 20, 2011 | 03:47 PM
W!d3b0dYr3X's Avatar
The nut locks the collar in place once adjusted. Loosen the nut then rotate the collar that attaches to the flapper 1-2 turns down to shorten the rod. Tighten the nut up. Take it for a ride if it needs more adjustment do it 1-2 turns at a time. When the rod is shortened it will require some muscle to pull it back up to the flapper to get it back on. This puts tension on the spring making it harder to open which gives u more boost.
Old Mar 20, 2011 | 06:16 PM
wantboost's Avatar
Who is Mr Robot?
or buy a boost controller. Sometimes you can over adjust the internal wastegate and damage the diaphragm and the spring
Old Mar 4, 2013 | 06:30 PM
jdmb18b1flip's Avatar
ok so to incress the boost on a internal wastgate turbo u just loosen the nut on the llil ord thing right,,,, do u need a spring ive been hearing about
Old Mar 4, 2013 | 06:31 PM
and how much boopst can one usuelly push
Old Mar 5, 2013 | 05:57 PM
xile6's Avatar
If the wastegate isnt adjustable then you cant up or lower the boost.
On an adjustable one. You unlock the nut. Then turb the arm out to lower boost ( it will leave the wastegate flap open some).
Or turn it in to shorten the rod and pull more pressure on the flapper.
I run 9.5psi on a sr20 t25. They come factory at 7-8psi.
Old Mar 5, 2013 | 07:41 PM
wantboost's Avatar
Who is Mr Robot?
I ran 14 on my sr, torque city lol
If the wastegate arm doesn't have a threaded section, then it isn't adjustable.
b18bcrxhf
Dec 21, 2006 05:42 PM
Hybrid96EK
Jan 31, 2006 05:57 PM
Boost Addict
May 3, 2004 12:30 PM
zseeanz
Nov 9, 2003 06:04 PM
