Adjustable External Wastegate? (SSAC)
Old May 5, 2005 | 06:05 AM
90LSpimpin's Avatar
Default Adjustable External Wastegate? (SSAC)
Sup folks. I've got an XS-Power (SSAC) External wastegate. I'm trying to figure out what size spring it came with and how much boost its for. took it apart and the spring is green, not sure if its a "small or big" springs because i have nothing to compare it to. In any case, Xs-Power.com says that the wastegate is adjustable from 3.63 - 19psi, as seen here http://cgi.ebay.com/ebaymotors...33742.
But they also have these http://cgi.ebay.com/ws/eBayISA...&rd=1
Can anyone tell me how this is done or give me an idea of what spring i should get for 7-9 psi. I was thinkin about gettin a 5ish psi spring and then uppin the boost with a MBC. Any response is greatly appreciated, unless you're here to tell me how much SSAC sux, then u can shutup . Thanks!
Old May 5, 2005 | 06:28 AM
tgreaves's Avatar
Default Re: Adjustable External Wastegate? (89SiPimpin)
You can use a mbc to raise the boost.. Or get the correct spring for the boost you want to run.. The info that came with your wastegate should say that spring is in it.. Try emailing the seller and get some info from him..
Im not going to go into ssac stuff since you didnt want to hear that, but just keep an eye out for boost creep..
Old May 5, 2005 | 06:49 AM
90LSpimpin's Avatar
Default Re: Adjustable External Wastegate? (tgreaves)
I bought it new off another Honda-tech member, but there was no manual or anything included so I'm really not sure. I'm gonna try to contact SSAC and see what they can tell me. And yea, I'll definately be watching carefully for boost creep. Thanks for the info!
Old May 5, 2005 | 07:49 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89SiPimpin &raquo;</TD></TR><TR><TD CLASS="quote"> took it apart and the spring is green, not sure if its a "small or big" springs because i have nothing to compare it to. </TD></TR></TABLE>
does it fill the whole seat or is the diameter of the spring a smaller than the ID of the wastegate spring seat? if the spring diameter isn't as wide as the wastegate seat it's a "small" spring.
Old May 5, 2005 | 08:20 AM
ginoboy1978's Avatar
Check out this thread written not to long ago.....might be a help:
https://honda-tech.com/zerothread?id=857805
DAN
Old May 5, 2005 | 07:27 PM
90LSpimpin's Avatar
Default Re: Adjustable External Wastegate? (ginoboy1978)
Here are pics of the spring. Big or Small?
Old May 5, 2005 | 08:32 PM
5thgencivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
Im not going to go into ssac stuff since you didnt want to hear that, but just keep an eye out for boost creep..</TD></TR></TABLE>
Have you run one?
Old May 5, 2005 | 09:34 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
he must've said that since most SSAC stuff are garbage perhaps the only way to figure that out is actually have it connected and watch the gauge to see where it's at but if it creeps then that's a diff story
Old May 6, 2005 | 01:07 AM
r cleghorn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89SiPimpin &raquo;</TD></TR><TR><TD CLASS="quote">Here are pics of the spring. Big or Small?</TD></TR></TABLE>
small
Old May 6, 2005 | 05:09 AM
notoriousB's Avatar
Default Re: Adjustable External Wastegate? (r cleghorn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r cleghorn &raquo;</TD></TR><TR><TD CLASS="quote">small</TD></TR></TABLE>
Txdragon
Feb 24, 2018 03:03 AM
chunkybs
Apr 13, 2008 08:17 AM
akira712
Aug 8, 2006 09:46 PM
_Cyclone_
May 4, 2005 02:32 PM
B00ST2nR
Nov 3, 2004 11:39 AM
