Adjsuting internal waste gate actuator??
Old Sep 4, 2004 | 05:18 PM
Drew Peacock's Avatar
Default Adjsuting internal waste gate actuator??
I have a IHI vf 22 with internal wastegate for some reason i can't get it to boost past 15psi I may have leak from my extra injectors, but that will be fixed soon. I am wondering if it could be caused by the wastegate opening to early? Would adjusting the actuator help?.. Using a MBC to controll boost
Old Sep 5, 2004 | 05:45 AM
maddog20's Avatar
Default Re: Adjsuting internal waste gate actuator?? (turbozxi)
Well I have had problems in the past with my greddy actuator. After 8 psi it would not like to hold boost.
So what I did was actually lower the boost on the actuator from around 8 psi to around 4 psi and used a MBC to raise the boost to the desired level. It now holds 16 psi steady.
Old Sep 5, 2004 | 10:36 PM
Default Re: Adjsuting internal waste gate actuator?? (maddog20)
CHeers I'll play with it and see what happens
Synapse
May 1, 2007 08:42 AM
Turbo-charged
Apr 1, 2005 08:32 AM
99lspwr
Mar 18, 2004 02:07 PM
slooogsr
Oct 26, 2003 01:36 PM
FUP23
Sep 30, 2002 09:15 PM
