Ack!
Old Jul 6, 2006 | 01:54 PM
beak's Avatar
Default Ack!
Ok so... after basically completely modding my car, it's time to fire it up.
It turns on, and exhaust is dumping out of the dumptube, sounds like it's not running a fire ring. I take the 38mm tial off, and low and behold, the fire ring is in there, no problems.
Anyone know why it might be leaking from there?
Old Jul 6, 2006 | 01:56 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Ack! (beak)
is it on correctly? there is a top and bottom to it. is the spring in the gate?
Old Jul 6, 2006 | 02:04 PM
beak's Avatar
Default Re: Ack! (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">is it on correctly? there is a top and bottom to it. is the spring in the gate?</TD></TR></TABLE>
yeah, it's a brand new wastegate.
Old Jul 6, 2006 | 02:11 PM
A.E Motoring's Avatar
gasket?
Old Jul 6, 2006 | 02:42 PM
importdude2000's Avatar
Default Re: Ack! (SPNFEDEH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH &raquo;</TD></TR><TR><TD CLASS="quote">gasket?</TD></TR></TABLE>
the firering is the gasket
Old Jul 6, 2006 | 02:51 PM
beak's Avatar
Default Re: Ack! (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">the firering is the gasket</TD></TR></TABLE>
Yep... I don't get it!!!
Old Jul 6, 2006 | 02:52 PM
oops, i know some ppl still use a gasket, but how about the flange? needs to be resurfaced?
Old Jul 6, 2006 | 02:54 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH &raquo;</TD></TR><TR><TD CLASS="quote">oops, i know some ppl still use a gasket, but how about the flange? needs to be resurfaced?</TD></TR></TABLE>
my thoughts too, the flange is probably warped.
Old Jul 6, 2006 | 05:40 PM
Mr. Badwrench
nah man, the 38mm still needs a gasket. the 44mm uses a v band and needs no gasket.
Old Jul 6, 2006 | 06:15 PM
wantboost's Avatar
Who is Mr Robot?
every tial 38mm gasket ive seen blows out after about 15 minutes... ive seen great results just using the fire ring (on a machined flange) and tightening till snug
i have a tial 44mm, it leaks everywhere BUT the v-band
Old Jul 6, 2006 | 06:19 PM
BlueSi2k's Avatar
Default Re: Ack! (wantboost)
I never ran a gasket on my 38mm becuase of all the stories I heard. Never had a problem leaking for 50k miles. I never ran one from the mani/turbo and turbo/dp either. As long as everything is true you should be fine.
The exhaust is coming out of the dumptube? or is it coming from where the wg meets the mani?
Old Jul 6, 2006 | 06:21 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Ack! (BlueSi2k)
he said out of the dumptube... which could mean either he has a fucked up spring, a bad valve, a bad wastegate or the flange is warped and the fire ring isnt seating right and its leaking through the wastegate
Old Jul 6, 2006 | 06:59 PM
beak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">he said out of the dumptube... which could mean either he has a fucked up spring, a bad valve, a bad wastegate or the flange is warped and the fire ring isnt seating right and its leaking through the wastegate</TD></TR></TABLE>
Yeah, out of the dumptube... like an open exhaust.
It's a brand new Tial 38mm. Fire ring looks flat. I'm stumped.
Old Jul 6, 2006 | 07:14 PM
BlueSi2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beak &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, out of the dumptube... like an open exhaust.
It's a brand new Tial 38mm. Fire ring looks flat. I'm stumped.</TD></TR></TABLE>
yea if its coming out of the dumptube then its probably not the fire ring. It has to be something wrong thats letting the valve open.
Old Jul 6, 2006 | 07:36 PM
beak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueSi2k &raquo;</TD></TR><TR><TD CLASS="quote">
yea if its coming out of the dumptube then its probably not the fire ring. It has to be something wrong thats letting the valve open.</TD></TR></TABLE>
I tapped a pressure source off my lower intercooler pipe coming right off my turbo.
I doubt it has 8.75psi of pressure, but do you think it could be somewhat related?
Old Jul 6, 2006 | 07:42 PM
wantboost's Avatar
Who is Mr Robot?
which fitting are you using on the wastegate. top or bottom?
Old Jul 9, 2006 | 12:21 PM
beak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">which fitting are you using on the wastegate. top or bottom?</TD></TR></TABLE>
Side
94lspower
May 9, 2007 02:53 AM
Dirt
Sep 21, 2005 03:53 PM
citronium
Sep 2, 2003 04:04 PM
Boostfed
Aug 1, 2003 07:43 AM
Cramerox
May 20, 2003 01:27 PM
