AC + light flywheel = stalling?
Old Jun 3, 2004 | 08:33 AM
Turbo E's Avatar
Default AC + light flywheel = stalling?
Just a quick question:
will a lightened flywheel coupled with an A/C system cause the car to stall?
it seems when its real hot outside my car shudders and sometimes stalls.
when its not so hot, it seems to work fine.
any rationale to this or is my car in need of tuning?
Old Jun 3, 2004 | 09:22 AM
SleepyEG's Avatar
Default Re: AC + light flywheel = stalling? (Turbo E 604)
I see from the sig it's a "10lb OEM flywheel" maybe it was not properly balanced when it was lightened? Even with an 8lb and A/C stalling should not be a problem..
Old Jun 3, 2004 | 10:25 AM
Turbo E's Avatar
well it runs fine when the AC is off.
Old Jun 3, 2004 | 10:34 AM
Sleepy_EG
Guest
Posts: n/a
Default Re: (Turbo E 604)
having the AC on causes a little load spike, and a corresponding small drop in RPM for a second, but my point was that it shouldn't stall out or vibrate excessively unless possibly something is up with the flywheel.
How/where was it lightened?
Yay for my first post
Old Jun 3, 2004 | 11:31 AM
DIRep972's Avatar
Smarter than you
just by chance your not using the AC input for nitrous/boost control are u?
Old Jun 3, 2004 | 12:43 PM
Turbo E's Avatar
yes it was balanced and idles smooth when no AC. and no, no NAWWWWZZZZ
Nicholas Bailey
May 17, 2016 10:36 AM
BlackTopSlayer
Jul 8, 2011 12:59 PM
TahitianEG
Transmission & Drivetrain
Apr 6, 2009 09:31 AM
2ToneEM1
Feb 22, 2008 08:03 AM
si90rex
Nov 20, 2007 08:50 PM
