about to install a JRSC... need advice
Old Jun 17, 2005 | 03:30 PM
boostedeghatch's Avatar
Default about to install a JRSC... need advice
i'm about to install a JRSC kit on a gsr motor
what spark plugs should i use?
i was thinking bkr7e-11 .. i think those are colder than stock
do i need to pull back timing?
i was thinking of leaving the timing at 16 degrees for 6psi.. i will be using 93 octane and colder spark plugs.
where do i get the 8psi pulley?
can i just buy the pulley somewhere?
thanks
Old Jun 17, 2005 | 04:21 PM
s2kdre's Avatar
Default Re: about to install a JRSC... need advice (boostedeghatch)
without msd or a retard ecu you cant have 16 degrees of timing, you'll blow your self into pieces. you can run with 10 degrees all the time, or get an ecu that retards the timing in boost.
Old Jun 17, 2005 | 04:22 PM
s2kdre's Avatar
Default Re: about to install a JRSC... need advice (jdmhonda)
you can get a smaller pulley and use a crv crank pulley and it will put you at 14psi
Old Jun 17, 2005 | 04:32 PM
i just want to up to 8psi
what pulley would i need to change out to get to 8psi?
Old Jun 17, 2005 | 04:33 PM
damn.. 10 degress.
i was going to set it back 4-6 degrees.
wouldn't i hear detonation if timing was too advanced?
Old Jun 17, 2005 | 04:55 PM
s2kdre's Avatar
i think they only have 6 and 9 psi, yea if the timing is advanced too much you will hear knocking unless you were using 100 octane or higher
Old Jun 17, 2005 | 05:06 PM
i can only get 93 octane
i think i should be alright with 4 degrees back from stock
E-gg's
Nov 14, 2005 06:49 AM
MenaceL.A.671
Sep 13, 2005 04:10 PM
Turbo-Honda
Sep 20, 2004 03:12 PM
