95 Civic hatch/d16y5 swap - Boost it?
Hi, I just got a 1995 eg hatch with a d16y5 swap in it with an Si tranny and y8 head. i was wondering if you guys could help me decide on what to do with it.
I was thinking either build it or boost it. im not looking for crazy power, around 250-300 is where i want to be at.
im looking for reliability and cost efficiency. ive heard you cant really build my engine so just boost it. if so what are good kits for my ideal hp range?
Any help is appreciated
Thank you
P.S. i already have buddy club racing suspension and skunk 2 camber kit with beak lower tie bar and purple blox LCAs
Thank you
PHANTOM MENACE
Re: New to hondas and am looking for help
Your use of "build it" seems to imply that you think you don't have to build it for boost. And while that is true in the literal sense, it doesn't mean don't. Hope you understand that.
Thank you
Thank you for the advice, i was also wondering if you, or anyone else, knew of good places to get a turbo kit. would you advise going through a shop for everything? or install myself? i know how to work on cars, im not a beginner. i know you have to get it tuned but is that all i need a shop for? do shops usually have good prices?
Thank you
Thank you
300whp on a turbo'd D will run you into the 4k+ area easily and get the idea of an all motor sohc out of your head it's the biggest waste around.
Re: 95 Civic hatch/d16y5 swap - Boost it?
Update, i found someone who used to work in a tune shop who will install and tune for under $400.
now all i need is a good turbo kit.
Is it best to buy a kit or buy each part individually? Ive seen kits for cheap on ebay, but the classic "ebay turbos are horrible" is why i dont want to jump on that.
i read around on some other forums and it sounds like if youre not a jack*** with it and dont try to shove p.s.i. down the turbo you will be fine.
Any help is much appreciated
Stay away from him.
Anyone that knows what they are doing won't sell themself that cheap.
A good tune on a dyno will run you about 300-500 and take 2 plus hours for a complete tune. Not no wot and idle bullshit tune.
Get a small turbo stay under 250whp and the motor will last you a long time. 300 is possible but its pushing it.
Don't rush start shopping around and don't do it cheap. The cheaper you get the less reliable it will be.
Stay away from him.
http://www.turboneticsinc.com/store/...product_id=530
is the turbo ive been looking at, it seems like a good choice. there are just some more places i was going to look at, like garrett.
I never narc'd on nobody!
It doesn't look like anyone has said this, so I'll go ahead and point it out: You are not going to reliably get 250-300 BHP out of your stock rotating assembly, period. Put some forged internals in along with a turbo, and sure, 250-300 is easy, but stock rods will snap like toothpicks at those power levels.
References thread, doesn't lost link to thread...suspetice
Longevity and reliability will be severely impacted past the 200-220 mark. On top of that, what one dyno reads as 250 could realistically be 225 - we all know how unreliable numbers can be when compared across dynos.
Can you do it? Sure. Should you do it for a daily driven car? No.
At the end of the day its a single slammer
Throw a rod? Pickup another bottom end for 50 bucks.
And that thread is here somewhere I just don't wana find it...
Don't test my gangster again..
CXRacing is Chinese crap. Don't waste your time on it, especially not on anything even remotely critical to the functioning of your car.
Eagle rods are the way to go for an affordable, reliable rod. Yes, you'll need new pistons. OEM pistons use a press-in wrist pin, whereas aftermarket rods use a floating pin. There are a decent number of options out there for pistons, but on a budget, I'm a fan of Wiseco, CP, and Supertech. You'll also need to replace your bearings. OEM or ACL. While you're doing all of this, it would be silly not to replace your head bolts. ARP. Done. None of this is even taking into account supporting mods that aren't strictly necessary, but would be a very good idea. Good tires can get pricey. 300 WHP with an open differential is no fun, unless you want people wondering if a squid just came through. Having power, but still having the garbage handling of a stock Civic? Yeah no.
Building an engine isn't as easy as "slap some rods in it and you're done". You can do it the cheap, lazy way and have a ticking time bomb under your hood, or you can do it the right way, get all of the necessary parts, install them properly, and have a solid, reliable little engine. Basically, if you want to go faster for cheaper, toss a small'ish turbo on there, get it tuned for 200, and have some fun. If you don't mind spending some cash, do all of the above, toss a slightly bigger turbo on it, get it tuned for 300, and have some fun.
What about timing belt, water pump, tensioner, mounts, shifter bushings, radiator, injectors, ems, gaskets, thermostat, thrust washers, oil pump seal, rear main seal, axel seals, valve seals, resurface the head, pickup tube gasket, .......
GDD Member
D-Series are getting harder and harder to find these days, good luck finding em for $50; this is probably the reason why the OP has an HX block with an EX head.
I actually did a B16 swap into some old lady's car two years ago because she couldn't find a used Y8 engine in the local wrecking yards, not even a core engine to rebuild. Her son found the complete B-Series swap for cheaper than the price of shipping a Y8 engine in from out of state.
Not sure if trolling...... I'm backing out of this. You could go at it with the shodan.
