91 SI toubo
Old Apr 2, 2021 | 05:21 AM
Lahie21's Avatar
Default 91 SI toubo
Hey guys and gals I'm new to this, anyways I would like to know if I could put a turbo on my 91 Honda Civic SI 1.6 L non VTEC , and if I do what damage will that do to my engine.
Old Apr 2, 2021 | 05:24 AM
Txdragon's Avatar
Default Re: 91 SI toubo
Yes, and it could potentially destroy the engine if not done properly. Any other questions?
Old Apr 2, 2021 | 05:26 AM
Lahie21's Avatar
So the engine that I have in there right now is a zc 1.6 L non VTEC, what will be the best motor to put in this
Old Apr 2, 2021 | 05:27 AM
Txdragon's Avatar
The "best" engine is HIGHLY subjective. Everyone has their favorites..
Old Apr 2, 2021 | 05:31 AM
Lahie21's Avatar
That is a reasonably understanding answer, I was thinking of putting a B series in there maybe a B18 what modifications do I need to make on this vehicle to get it to work right
Old Apr 2, 2021 | 09:46 PM
highschooler's Avatar
Yes, you can do a turbo set up on that engine as long as it has good compression (do a compression test of the cylinders), and a leak down test. As long as it is in good condition, isn't burning oil/coolant, or knocking, the engine should handle up to about 220 horsepower. The easiest way to do it is use a pre-fabricated turbo kit. Make sure you have something to tune for extra fuel while boosting, then no damage should occur.
If you don't set it up correct, the engine could be ruined, however it's not too difficult. Or, just have a shop do the engine tests, turbo kit install, and fuel system tuning if you aren't capable yourself.
Old Apr 3, 2021 | 05:47 AM
Stopsign32v's Avatar
Loved
1991 Civic Si would be sick with a K series motor
crxrider07
Aug 30, 2008 04:15 PM
swiftz6
Oct 27, 2004 07:57 PM
89CRX89
11
Jul 18, 2004 07:39 PM
DownRightPinoy
Jun 27, 2003 07:16 AM
