'90 CRX / JDM B18c / JRSC / S300 / Evans Tuning......**VIDEO**
moderator emeritus
Introducing John's EMACULATE 1990 CRX si:
Mods include:
B18C-r, JRSC, LHT intercooler, Hasport mounts / axles / linkage / harness, LoCash ECU adapter, TODA cam gears / timing belt / oil pump, Supertech valves, ARP studs, Koyo rad, Flex-a-lite fans, Samco hoses, Hondata S300, Walbro 255 fuel pump, AEM rail, Aeromotive FPR, RC 440cc injectors, MSD coil / SCI+ ignition / wires, AEM air intake, Kamikaze header, Greddy SP2 exhaust, ACT clutch, ACT flywheel, Full Race traction bar, Progress coilovers, Neuspeed fr & rr anti-roll bars / fr & rr tower braces / lower brace, Ingals fr & rr camber kits, Fast brake 11" fr & rr brake conversion, 15/16 master cylinder, rebult OEM steering rack, Hyperflex bushing kit, Prothane trailing arm & toe bushing kit, Skunk extended studs & lugs, Rota GT-3s, BFG KDW 205/50 R15, JDM SiR front coversion with ViS hood, JDM SiR spoiler, SiR cluster with KPH-MPH convertor, Skunk dual bend shifter, Type R shift boot, SoS NSX rapid shift ****, Complete re-paint every piece of plastic trim & glass replaced with OEM, Every suspension component powder coated
http://media.putfile.com/Johns-JRSC-CRX
-- I would like to add that this is my first time EVER editing a video. I think it turned out pretty well for my first editing job. So if you think it sucks, you can shove it
Currently working on getting a downloadable version.
http://www.glasssphere.net/crx
^^ complete review of the CRX build
if you want any other info, visit http://www.tuner-junction.com. His sn is Jadkar and owns TJ
Modified by 98vtec at 11:39 PM 4/6/2006
Mods include:
Re: '90 CRX / JDM B18c / JRSC / S300 / Evans Tuning......**VIDEO** (98vtec)
very smooth power band
Is thats Lht intercooler a big difference , also is it expensive??? I have a 2001 Gsr JRSC and i took it to get a dyno/ tuning done..i got 224 hp and 143tor. I needed bigger injector's not enough fuel to the engine..thats sad ..are the 440cc good enough or should i go bigger?..i want more power..something similar to yours!!!! thanx
Re: '90 CRX / JDM B18c / JRSC / S300 / Evans Tuning......**VIDEO** (Quad-Damage)
i saw this over on Jeff's site.....sick powerband....nice vid too
very nice buildup on the car...very well thought out parts for the setup
this car is amazing. so clean, and soo well done. EMACULATE is the only word to describe it. where in the heck did he get door skins from? theyre a discontinued part! ill have to sign up and ask him in t-j.
Re: (H.A.R.T B18C1EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.A.R.T B18C1EG6 »</TD></TR><TR><TD CLASS="quote">nice </TD></TR></TABLE>
moderator emeritus
Re: (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX »</TD></TR><TR><TD CLASS="quote">Very nice CRX.
You gotto love the blower when it's set up and tuned right.
Good Job !</TD></TR></TABLE>
he was VERY satisfied with the intercooler
Re: '90 CRX / JDM B18c / JRSC / S300 / Evans Tuning......**VIDEO** (mr_hahn73)
Thanks for all the comments guys!!! I'm the original owner of this CRX. She's been off the road for 9 years and last May I decided to rebuild the ENTIRE car. It was well worth it and this CRX is staying with me forever so I didn't mind taking my time.
For some answers....
GSR4life - The 440cc injectors are fine for way more HP then you think (per Jeff Evans). I'm actually running 440cc with a Walbro 190 fuel pump. The LHT intercooler makes an enormous difference!! Plus you get a huge "piece of mind".
bch4528 - I think you already PM'd me..... but yeah I bought the last Right door skin and the 2nd to last left skin. Farewell to parts for our beloved CRXs
ZacCarter - I had a JDM 4:1 header (back when I was going all motor). I switched to a Kamikaze with 2.5 outlet as per Jeff Evan's suggestion. The dyno and runs were made with the Kamikaze.
Bryson - heheh....that's my wife That turn is posted 40mph and I went through at about 75-80mph. No worries I know that road like the back of my hand and I used to take my NSX through there to test my suspension adjustments. This was the first time through after setting up the CRXs suspension and engine and I took the turn as fast as my longer wheelbased NSX. The CRX is setup just about perfect now!! Can't wait for WGI!!!
Re: (ZacCarter)
Save us Link for the Putfile Video
http://f3.putfile.com/videos/d2-9523223049.wmv
Modified by r.p.m at 7:04 AM 4/13/2006
Re: (r.p.m)
Link not working for me.....
I'm still trying to get a hole of Blake so he can FTP me the video, once he does this I will publish it on my server.
