8psi on stock B16?
Old Oct 30, 2007 | 05:18 PM
cameron4776's Avatar
Default 8psi on stock B16?
Im getting ready to get my car back from being turboed. Some people have said that they have blew there engine just on 7psi. This makes me nervous bout my car, so I need some advice.
Old Oct 30, 2007 | 06:48 PM
Evilparadize's Avatar
Default Re: 8psi on stock B16? (cameron4776)
As long as your car was tuned professionally by a reputable shop, I wouldn’t worry at all. 1) What does your set-up consist of? From engine mods to turbo size, etc.
2) What engine management are you using?
3) Who installed and tuned your set-up?
Old Oct 30, 2007 | 06:49 PM
94c1v1cex's Avatar
what are you asking??
you said you're getting ready to get your car back from being turboed. does this mean it was already boosted?
as in psi... psi doesn't rate what the motor can handle. it's all in the turbo size... for example... 10 psi from a dsm 14b turbo is a completely different world from 10 psi from a gt35r...
Old Oct 30, 2007 | 08:14 PM
Schister66's Avatar
Man U FTW
As was already said, PSI doesnt mean a damn thing...everything is based on the shear amount of power created. Stay around 300whp or less if you want it to be reliable and last for a while...
Old Nov 5, 2007 | 05:14 PM
yeh im getting my car back and it is turboed. at 8psi it will be around 300hp. and its on crome, with a garret t3/t04e .50 trim.
Old Nov 5, 2007 | 05:59 PM
jlfrnce's Avatar
Default Re: (cameron4776)
show us some pics then!
Old Nov 5, 2007 | 06:12 PM
Sr420Det's Avatar
I always blow mind up around 135 or so, so keep it under 125 and i think you'll be alright.
Old Nov 5, 2007 | 08:11 PM
Schister66's Avatar
Man U FTW
8psi on a 50trim is not going to get you 300whp unless you're on a magic dyno...i'm running a bigger turbo on a fairly efficient setup and would be making 300whp around 9psi....
Old Nov 7, 2007 | 08:10 PM
Default Re: (Schister66)
Well the guy that is building it said I will only be able to run like 5-6psi on the stock internals. This upsets me. Is it becauce the B16 high compression?
Old Nov 7, 2007 | 08:11 PM
Schister66's Avatar
Man U FTW
OMG....you can easily make 300whp on a stock internal B16. My buddy Mike at SLS made 389whp on his BONE STOCK B16 running E85. Just remember that 90% of the people you talk to in life have no idea what they're talking about when it comes to turbo setups
Old Nov 7, 2007 | 08:58 PM
blinx9900's Avatar
you never know how abused an engine is when it comes from japan, i dont care what anybody says, some engines are in better shape than others, this is going to determine its life under boost, among other things...
Old Nov 7, 2007 | 09:28 PM
TspEk9's Avatar
i just turboed my b16 at 7psi, its tuned by speedfactory runs really good, healthy motor before i turboed it, its in for a clutch cc2
Old Nov 8, 2007 | 05:20 AM
LSTEG98's Avatar
Headstuds and a good tune are key man. I have a boosted ls teg with stock block and boost 15psi daily. I have a buddy with a ef b16 and boosts like 20 pounds with race gas at the track then drives it home after. Just make sure you get headstuds and the tune is good if you want to boost over 10psi and what kind of map sensor you running?
Old Nov 8, 2007 | 05:56 AM
adseguy's Avatar
Default Re: (LSTEG98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG98 &raquo;</TD></TR><TR><TD CLASS="quote">Headstuds and a good tune are key man. I have a boosted ls teg with stock block and boost 15psi daily. I have a buddy with a ef b16 and boosts like 20 pounds with race gas at the track then drives it home after. Just make sure you get headstuds and the tune is good if you want to boost over 10psi and what kind of map sensor you running?</TD></TR></TABLE>
Yeah head studs on a b series engine...that's the keep
Old Nov 8, 2007 | 06:33 AM
LSTEG98's Avatar
again good tune u will be fine anything over 10psi i say get headstuds and a 3bar
Old Nov 8, 2007 | 10:27 AM
Schister66's Avatar
Man U FTW
God damn, some days i swear people are retarded!!
How many times do i have to say this...who gives a expletive about PSI. That has NO relevance to ANYTHING! Base things in terms of horsepower, or better yet torque. You can use a K03 at 30psi and not make the same power as a GT4202r at 10psi....there's absolutely NO comparison.
If you're running pump gas (91-93 octane) then keep your goals under 315-325whp....if you're running race gas or E85, then shoot higher. Its that simple
Old Nov 8, 2007 | 12:21 PM
Glove's Avatar
your builder said you can only run 6 psi on stock b16?
I would take my car to another shop if I were you.
Old Nov 8, 2007 | 12:59 PM
street dream gsr's Avatar
* B A N N E D *
Default Re: 8psi on stock B16? (Glove)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Glove &raquo;</TD></TR><TR><TD CLASS="quote">your builder said you can only run 6 psi on stock b16?
Old Nov 8, 2007 | 01:03 PM
slow96coupe's Avatar
$10 says its SSAC...
I was running 14psi on a stock b16 w/ an sc50
beat the hell out of it all day long... never had a problem.
Old Nov 8, 2007 | 01:06 PM
spuddo01's Avatar
Default Re: 8psi on stock B16? (street dream gsr)
i got brand new golden eagle head studs and bolts for sale 50 bucks
Old Nov 8, 2007 | 01:42 PM
dohc_vtec_acura's Avatar
Default Re: 8psi on stock B16? (spuddo01)
What u got for a turbo. Cause i got a 1990 integra with a b16 and i am looking to turbo it. just looking for some options.
Old Nov 8, 2007 | 05:11 PM
msinsky14's Avatar
Default Re: (slow96coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow96coupe &raquo;</TD></TR><TR><TD CLASS="quote">$10 says its SSAC...
beat the hell out of it all day long... never had a problem. </TD></TR></TABLE>
damn really? what were its numbers?
Old Nov 8, 2007 | 07:05 PM
B.'s Avatar
B.
400 HP Club
Default Re: (msinsky14)
it can be done....
Old Nov 9, 2007 | 11:46 AM
msinsky14's Avatar
Default Re: (B.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B. &raquo;</TD></TR><TR><TD CLASS="quote">it can be done.... </TD></TR></TABLE>
i see ur sig, what other mods are done and what turbo are you running? and im guessing u had an insanely good tune.
Old Nov 9, 2007 | 02:23 PM
agrn93ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">God damn, some days i swear people are retarded!!
If you're running pump gas (91-93 octane) then keep your goals under 315-325whp....if you're running race gas or E85, then shoot higher. Its that simple</TD></TR></TABLE>
To the original poster, you should really focus on these two posts, 6PSI is pansy **** to a B series on any turbo. even though as stated many times PSI isnt the key factor to be focusing on. Get a better tuner is the first thing you need to do.
