880 injetcors?
Old Jun 28, 2007 | 10:48 AM
ACrite3404's Avatar
Default 880 injetcors?
ok here is what the set-up will be T3/T4 wit .50ar. my build is gonna be forged arias 81.50 9:1 pistons with eagle forged rods, 880 precision injectors FMIC dont have the excat dimensions on the intercooler, XS power blow off, Tial wastegate, 3" 5bolt downpipe, blitz sbc type s digital boost controller, Hondata s200 wit boost option and other options jus dont remember.
Well the question is once it is all put together and done will i be able to drive it around wit the 880's wit a resistor box untuned? or should i jus use the stock injectors until its tuned? i really dont plan on driving it but to the tuner which is around 60miles away.
Old Jun 28, 2007 | 12:14 PM
dpetro1's Avatar
Default Re: 880 injetcors? (ACrite3404)
it depends. do you have a basemap on the s200?? if not then keep the stockers. a virgin ecu will not run 880s since they ae more than 3 times larger than stock.
Old Jun 28, 2007 | 12:22 PM
boostedcivicsir's Avatar
Mr. Badwrench
p and h's are kinda weird on sat'd ecu's not to say they wont work, i ran 1200's last year. but a base map will prob let it idle. without any fine tuning. that far, you may be better running a stock ecu with sat injectors.
Old Jun 28, 2007 | 04:38 PM
ACrite3404's Avatar
Default Re: 880 injetcors? (dpetro1)
hondata is already socketed to a pr4 ecu
Old Jun 29, 2007 | 07:44 PM
slowb20civic's Avatar
are you at least going to be on some kind of basemap for the 880's ???
Tuning is Key !!!
Old Jun 30, 2007 | 09:19 AM
ACrite3404's Avatar
Default Re: 880 injetcors? (slowb20civic)
do i need a fpr also or will i be ok with the stock one
lurkin' eg
Dec 16, 2007 09:11 PM
19sec beast
Jun 1, 2005 04:30 PM
94lsboost
Dec 8, 2004 05:26 AM
crex23
Oct 5, 2004 11:01 AM
angela_itr
Jul 9, 2004 12:58 PM
