85mm too big for boost?
Old Mar 1, 2009 | 07:17 PM
  #26
guy_from_nerk's Avatar
Default Re: 85mm too big for boost?
3rd shift you have a pm
Old Mar 3, 2009 | 06:29 AM
  #27
Garcia-Racing's Avatar
Originally Posted by blinx9900
at what power level? what size turbo and pis?
well even if they were the same thickness of oem sleeves they are made of a far stronger material... but honestly 85mm does not look like oem thickness, granted its not as thick as a stock bore sleeved motor...
600ish on the dyno. The motor had made almost 700, but it was just over 600 when it cracked the sleeve. t72, don't remeber psi. Not the only one I've seen fail, but the most recent. My opinion, it's better to leave the walls thicker and stronger and let the turbo do its job.
Old Mar 3, 2009 | 04:09 PM
  #28
blinx9900's Avatar
Cant argue with that.
Old Mar 3, 2009 | 04:39 PM
  #29
nonvtecallmotor's Avatar
Originally Posted by kte324
I wonder how much you could boost with 85
I've ran as much as 35psi. Jason Hunt ran as much as 45psi with 1/2" head studs in the coupe.
DAteg402
Dec 4, 2008 03:09 AM
power11
Jun 10, 2007 06:47 PM
s2kkid
Sep 11, 2004 07:36 AM
Zerotls
10
Apr 18, 2004 12:10 AM
