84.5mm overbore ??'s
Old Apr 16, 2002 | 11:08 PM
blkDOHCsol's Avatar
New User
Default 84.5mm overbore ??'s
ok, first of all, I have a del sol vtec with drag III turbo. I am thinking about getting my block resleeved by golden eagle and getting 84.5mm 9.5:1 ENDYN rollerwaves. With the 84.5mm overbore, can I use an 84mm headgasket? Also would I have to modify the head in anyway? What are the drawbacks to my plan for a bottom end? any other advice?
Old Apr 17, 2002 | 05:32 AM
newsense's Avatar
New User
Default Re: 84.5mm overbore ??'s (blkDOHCsol)
I believe you would use a 85mm gasket from cometic. As far as the head its a good idea to have the combustion chambers enlarged to 84.5mm as well. My head is at Endyn as we speak having this done. If you do that then you might as well go with oversized valves, springs and retainers. And if you do THAT then you might as well get the head ported. And well you get the idea... It gets expensive.
Old Apr 17, 2002 | 11:11 PM
IntegD's Avatar
New User
Default Re: 84.5mm overbore ??'s (newsense)
so can one run with just the 84mm bottom end and stock head?
Old Apr 18, 2002 | 10:43 AM
newsense's Avatar
New User
Default Re: 84.5mm overbore ??'s (IntegD)
You can do it but it makes the edge around your combustion chamber on the deck of your head more prone to detonation.
Old Apr 18, 2002 | 11:05 AM
Seraph0's Avatar
I need to read the FI section again more
a1320honda
Aug 6, 2008 01:39 AM
si0385.
Feb 13, 2006 07:40 PM
t-blizzard
Feb 15, 2003 01:56 AM
servion
Oct 20, 2002 10:37 PM
done
Oct 3, 2002 08:37 AM
