I’m not a young guy Lol, 46 at the moment 🥸. I have been into the Honda game since 2001. Yes, I felt in love with Honda since F&F 1, yeah I ain’t a shame of said that 🤭.
I destroyed my last car back in 2021 while I was racing at Palm Beach International Raceway in Florida. Car hit the wall probably at 100 mph. It was a nice and clean EG Hatchback 😣. I sold the shell and bought another one. I started adding some safety stuff as roll cage (I didn’t have one in my other car). So here is my build thread. Open to suggestions 🫡 Car gonna be taken to track just to check times. I building the car mostly to sit on a chair and contemplate it Lol.
List updated on 03/22/2024*
- 81.5mm B18 LS Ramey Racing o-ringed / Sleeved block.
- Golden Eagle main girdle / arp main studs (line bore / hone work done)
- Wiseco 81.5mm pistons / upgraded pins.
- Brian Crower I-beams rod with arp 625 bolts.
- ACL Race bearings.
- ATI super damper.
- Ported GSR head (Melvin Ports).
- Ferrea 6000 intake valve / Ferrea Comp Plus Exh valves.
- Ferrea guides, valve steam seals and lock keepers.
- GSC dual springs / Ti retainers.
- Skunk2 LMAs
- Skunk2 Pro 1 cams.
- Skunk2 Ultra Race IM (2 LTS spacer).
- Schmuckbuilt T3 Top mount modified to run dual 45mm Wastegate Valves.
- Pulsar 6862G DBB T51R mod Turbo .83ar.
- Pulsar New Gen 45mm WG valves (dual).
- 3” intercooler piping.
- Treadstone TR-1245 1000hp IC (22x12.5x4.5 core).
- Tial BOV.
- Ross Machine 90mm Throttle Body.
- B16 transmission with Mfactory 4.05 FD.
- Libertay Face Plate gears (Dog box engagement) / GSR 4th gear.
- Mfactory 5th gear cuff.
- OBX LSD (Need to upgrade).
- Competition Clutch Twin disc.
- Thinking on axles 🤔.
- Fueltech FT-550 ecu.
- Grams 2200cc Injectors.
- Dual Walbro 450 fuel pumps.
- 10an feed / 8an return line.
- Speedfactory Fuel Rail.
- Exospeed 3 pieces front end.
- 8 points roll cage.
- I got my previous set of VMS drag wheels M&H 24.5x8.5-13 and M&H rear skinnies.
- Thinking to run MT 235/60-15 and VMS 15x8 wheels
for the street.
My goal is 800WHP for track / 600-650WHP for the street. I also owns a 2009 Subaru WRX 410AWHP. Planning to keep the civic in the garage and drive around town on weekends, yeah I’m old remember that guys.
Reason: Listing update
Looks like a fun build! The Faceplated gears are nice, but anything over 600whp really needs a stronger set of gears. My set of treated gears didn’t last long at all, I broke gears 4 different times under 700hp. At 800hp I would definitely look into some strong gears
I hope those face plated gear set holds at least a few track days while I’m testing the car. Other than that it gonna be at 600-650 the most of the time. After my accident wife doesn’t want me to race again, so you might know what I mean. I told her I’ll be at track just a couple times to set the car up.
i understand, my wife gave up and just wants to make sure I use proper safety gear now, she just closes her ears to the 150mph + speeds
If the car is caged, and you're wearing a helmet with a proper seat and harness then you're most likely safer at the track than you are on a public highway in a commuter car honestly.
Yup, You’re right. I’m trying to explain that to wife 🥴
I don't know if it'd help or hurt your case but this crash here has always really impressed me as far as appreciating proper safety equipment.
Brian from VTEC Academy went sideways at almost 200MPH and flipped his car I think like 10 times, at one point you see the entire engine just yeet itself about 15 feet up into the air out of the bay.
He didn't even lose consciousness, and made a very quick and full recovery. No lasting injuries of any sort, if I remember right not even broken bones. There's another video out there where they document this in more detail including commentary from Brian.
I went today to Treadstone headquarters in Miami, Fl to pick up my TR-1245 (1000hp) intercooler. Core size 22x12.5x4.5. Treadstone’s crew are awesome!!
Next step on the list is the Odyssey Fab 8” weight bar. Little by little 🙌🏽
Guys! What size spacer do you recommend to run in my SK2 Ultra Race IM?? 1LT or 2 LT? 🤔 I’m planning to stay around 800WHP (limited for the transmission).
I’ll be running a 74-76mm TB instead the 90mm, I think 90mm is overkill for now.
I have trying to find info about the spacer but I didn’t find anything.
I went with the 2LT spacer so actual volume of the Ultra Race is 5.5 LTS. After reading and reading about the throttle I decided to go with the 90mm Ross Machine Racing. I’ll running a BBK Mustang 5.0 TPS and thinking to go with a AEM 5 bar map sensor attached to back ports of the Ultra Race.
I own a small powder coat business so I’ll be doing a lot of powder and cerakote works on the car. I already did the valve cover. I’ll be doing the IM soon. My IG: @rboost77.
GSR head came back from Melvin’s ports. Ported job looks awesome! I keep moving forward with the build through these hard days we’re living in 🇺🇸 (inflation).
I don't post often but am following the build! My own build has been on hold a solid 2 years, finally just towed it off to a shop to at least get some progress made on it. I completely get it man.
Also please post pics of the IM when it's done in powder. I tried to have mine done and the shop said they couldn't but I don't recall exactly why.
