8:5:1 d16y8
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GiNuWiNe »</TD></TR><TR><TD CLASS="quote">Would this type of compression ratio for daily driving suck? Because i'm thinking about buying Vitara pistons</TD></TR></TABLE>
No, drives fine on my friends crx (a6 block z6 head, 8.5:1 compression). 205whp on 6 psi. He does mid 13's at 103ish mph...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GiNuWiNe »</TD></TR><TR><TD CLASS="quote">As of right now my goal is around 200whp. I just want to be in the low 14's in street trim</TD></TR></TABLE>
stock pistons will do fine with a good tune
Guest
Posts: n/a
not 100% sure but I would say you'll lose about 10-20 whp and maybe lil more torque. You could just buy a spare block, and rebuild it completely (new sleeves) everything else.It wouldn't even have to be a z6..since everything (except for the casing) would be brand new.....
if you put those pistons in a z6 won't it be more like 8:1 compression? i was thinking of putting some of those pistons in my z6 and turning up the boost to about 15 psi and see how it runs. anyone on here know how that would be as a daily driver. the turbo would be a greddy turbo kit, 15g that i already have on the car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FMIDRC Racer »</TD></TR><TR><TD CLASS="quote">if you put those pistons in a z6 won't it be more like 8:1 compression? i was thinking of putting some of those pistons in my z6 and turning up the boost to about 15 psi and see how it runs. anyone on here know how that would be as a daily driver. the turbo would be a greddy turbo kit, 15g that i already have on the car. </TD></TR></TABLE>
Im going to run that setup. Im going to get the block decked a bit and run a y8 gasket to try and get the compression up a wee bit. The 15g's are good for 260hp apparently so id like to try and max it out.
Im just still trying to figure out how to make ls rods work.
https://honda-tech.com/zerothread?id=891131
Setup as follows:
Sleeved stock bore 1.6L D16y8
8:1 arias pistons
Crower rods
Stock unported head with 1mm bigger vales intake and exhaust.
Zex 59300 cam
T3 BLOWZILLA Turbo.
Skunk 2 intake manifold.
Setup as follows:
8:1 arias pistons
Crower rods
Zex 59300 cam
T3 BLOWZILLA Turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportHatch »</TD></TR><TR><TD CLASS="quote">Ya they are those motorcycle pistons. I'd say go for it.
Yager-</TD></TR></TABLE>
A Suzuki Vitara isn't a motorcycle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">A Suzuki Vitara isn't a motorcycle.
Ya your right. I never really checked up on it till now. That's just what someone told me. I'm actually thinking about running this now.
Yager-
</TD></TR></TABLE>Ya your right. I never really checked up on it till now. That's just what someone told me. I'm actually thinking about running this now.
Yager-
fdjizm
Dec 10, 2006 10:04 AM
Tzarinque
Oct 18, 2006 07:02 PM
