8.3-1 compression steetcar ????
Old Jul 2, 2005 | 04:15 AM
Boosted2K's Avatar
Default 8.3-1 compression steetcar ????
Basically I can get a good deal on a GSR shortblock (AEBS, Pauter, Ross 8.5-1 pistons).
If I use a b16 head, should be around 8.3-1 compression. How will this perform as a street motor, I'm running a precision SC50 for now.
Also the shortblock is a spare from a race car being parted out, ran on meth. Would the tolerence of the motor be to loose for the street??
Thanks
Old Jul 2, 2005 | 04:28 AM
MiraiZ's Avatar
Default Re: 8.3-1 compression steetcar ???? (Boosted2K)
LAG
Old Jul 2, 2005 | 04:57 AM
Alfa Turbo's Avatar
Default Re: 8.3-1 compression steetcar ???? (MiraiZ)
Going out in the cold without a jacket does NOT give you a cold.
Girls do NOT give you coodies and,
Low compression does NOT create lag; improper turbo selection does.
When Jeff's website is up again (Boosted Hybrid) you will find a great article in the tech section on this subject. Reading it would help your understanding.
I run 7.8:1 in a street car and would gladly trade compression for boost.
Old Jul 2, 2005 | 05:24 AM
Boostage's Avatar
Default Re: 8.3-1 compression steetcar ???? (Alfa Turbo)
sc50 with a 3inch exhuast wont lag any more with 8.3:1 c/r than it would with 9.8:1
Old Jul 2, 2005 | 11:45 AM
JDogg's Avatar
compression does not effect lag
tune it right and you wontknow the difference
Old Jul 2, 2005 | 12:21 PM
uglyasscivic's Avatar
Default Re: 8.3-1 compression steetcar ???? (JDogg)
Higher compression increases the thermal efficiency of your engine. I personally like 9.5:1 to 10.0:1 Compression ratios.
Old Jul 2, 2005 | 01:55 PM
Turbocivic94's Avatar
Default Re: 8.3-1 compression steetcar ???? (uglyasscivic)
Its little low for my liking, mine is around 9:5:1
Old Jul 2, 2005 | 03:05 PM
Boosted2K's Avatar
Default Re: 8.3-1 compression steetcar ???? (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">Its little low for my liking, mine is around 9:5:1</TD></TR></TABLE>
Thats kinda of what I am thinking,
I run a B16 right now and will probably just build this motor 83mm 9-9.5 to 1 when the time comes.
I guess I am just falling for all the hype of the GSR botom end being far superior to the B16......... Hell, I'm only shooting for around the 400WHP range
I might even try it on stock sleeves and put the other 1000 somewhere else
Old Jul 2, 2005 | 03:53 PM
Chip's Avatar
The extra torque of the GSR motor is well worth it for a street car.
Old Jul 2, 2005 | 07:54 PM
Try doing lsvtec. I always have good luck with them. currently I'm running gsr block with ls crank and b16a head. I have a back up block which has old darton open deck sleeves with 81.5mm 9:8:1 weisco pistons and eagle rods. I might be selling that block though. good luck with whatever you do. I would go ls block since they're cheap and you can find them easy.
Old Jul 2, 2005 | 08:05 PM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alfa Turbo &raquo;</TD></TR><TR><TD CLASS="quote">Going out in the cold without a jacket does NOT give you a cold.
Low compression does NOT create lag; improper turbo selection does.</TD></TR></TABLE>
I like how this guy thinks. So then where do coodies really come from??
Old Jul 3, 2005 | 12:08 PM
Boosted2K's Avatar
Default Re: 8.3-1 compression steetcar ???? (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">The extra torque of the GSR motor is well worth it for a street car.</TD></TR></TABLE>
Does anybody have a rough idea in the difference in torque between a GSR and B16, given the same build and turbo set-up.
Basically using the same B16 head and same compression ratio
Old Jul 3, 2005 | 12:35 PM
Ri5e's Avatar
I run 7.8:1 in a street car and would gladly trade compression for boost.</TD></TR></TABLE>
oh really...what if I ran 2.0:1 compression, I would need to run some puny little turbos?
Old Jul 3, 2005 | 01:17 PM
Alfa Turbo's Avatar
Default Re: 8.3-1 compression steetcar ???? (TurboSmart)
Well... there are limits to just about everything, your intellect notwithstanding!
Old Jul 3, 2005 | 03:57 PM
Boosted2K's Avatar
If you have no info to share, please stay the hell out of my thread
Old Jul 3, 2005 | 07:08 PM
Dr. D-Series's Avatar
7.5:1 on a D series here.
No problems driving off boost.
At all.
Your 1.8 should be just fine.
rudebwoy
May 24, 2005 01:30 PM
LSEGHATCH
Oct 6, 2004 07:44 PM
s0liDyNe
Jul 19, 2003 10:24 PM
K20 EG
Jun 17, 2003 11:26 AM
98civicEX
Jul 31, 2002 07:16 PM
