75 shot on LS motor?
Hmm, it's a b18b first off, or b18a, depends what year teg. Also, yea you should be fine, it's a relatively low compression motor, so nitrous, a little ignition retard and colder plugs, and your set!
Depending on what kit you use, you won't have to retard your timing. If yo run an NX kit (wet) you'll be fine on stock timing, but if you use a dry kiy, I would retard it at least one degree.
Sorry if im hijacking the thread but i asked this same questions somewhere else but i didn't receive help. I have a b18b and was plannin on using 100 shot dry, so i would need to bump the fuel pressure and retard the timing how many degrees, besides using colder plugs and running 93 octane. Anywhee know of a page that shows how to set timing or retard it using a timin gun. What's the base timing for a 96ls. Thank you.
